New interface
Poster communications
Understanding the impact of recurrent interactions on population tuning: Application to MT cells characterization
Abstract : A ring network model under neural fields formalism with a structured input is studied. Bifurcation analysis is applied to understand the behaviour of the network model under different connectivity regimes and input conditions. The parameter regimes over which the localised input bumps could be preserved, combined or selected are used to identify the potential network regimes under which direction selective cells in MT area exhibiting analogous behaviour could be operating. The parameter regimes are further explored to identify possible transitions in the tuning behaviour with respect to change of driving stimuli as observed in experimental recordings.
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/hal-01377606
Contributor : N V Kartheek Medathati Connect in order to contact the contributor
Submitted on : Friday, October 7, 2016 - 11:35:05 AM
Last modification on : Friday, November 18, 2022 - 9:26:35 AM
Long-term archiving on: : Friday, February 3, 2017 - 6:57:15 PM
File
Medathati_AREADNE_Poster_Final...
Identifiers
  • HAL Id : hal-01377606, version 1
Citation
N V Kartheek Medathati, Andrew Isaac Meso, Guillaume S. Masson, Pierre Kornprobst, James Rankin. Understanding the impact of recurrent interactions on population tuning: Application to MT cells characterization. AREADNE: Research in Encoding And Decoding of Neural Ensembles, Jun 2016, Santorini, Greece. ⟨hal-01377606⟩
Share
Metrics
Record views
276
Files downloads
29
