Advanced High Dynamic Range Imaging: Theory and Practice, 2011. ,
DOI : 10.1201/b11373
Real Pixels, " in Graphics Gems II, James Arvo, pp.80-83, 1991. ,
OpenEXR, HDR Image File Format ,
An adaptive Logluv transform for High Dynamic Range video compression, 2010 IEEE International Conference on Image Processing, 2010. ,
DOI : 10.1109/ICIP.2010.5654069
LogLuv Encoding for Full-gamut Highdynamic Range Images, J. Graph. Tools, pp.15-31, 1998. ,
Call for Evidence (CfE) for HDR and WCG Video Coding, Tech. Rep. N15083, ISO/IEC JTC1/SC29/WG11, 2015. ,
Perceptual Signal Coding for More Efficient Usage of Bit Codes, 2012. ,
Photographic Tone Reproduction for Digital Images, ACM Trans. Graph, 2002. ,
Evaluation of Tone Mapping Operators Using a High Dynamic Range Display, ACM Trans. Graph, 2005. ,
Tone mapping of HDR images: A review, 2012 4th International Conference on Intelligent and Advanced Systems (ICIAS2012), 2012. ,
DOI : 10.1109/ICIAS.2012.6306220
JPEG-HDR: A Backwardscompatible , High Dynamic Range Extension to JPEG, ACM Siggraph Courses, 2006. ,
Two-layer Coding Algorithm for High Dynamic Range Images Based on Luminance Compensation Optimizing a Tone Curve for Backward-Compatible High Dynamic Range Image and Video Compression, J. Vis. Comun. Image Represent. IEEE Trans. on Image Processing, vol.14, 2007. ,
Improved Tone Mapping Operator for HDR Coding Optimizing the Distortion/Spatial Complexity Tradeoff, Signal Processing Conference (EUSIPCO) Proc. of the European, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01141081
Rate distortion optimized tone curve for high dynamic range compression, Signal Processing Conference Proc. of the European, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00998480
Optimized tone mapping with LDR image quality constraint for backward-compatible high dynamic range image and video coding, 2013 IEEE International Conference on Image Processing, 2013. ,
DOI : 10.1109/ICIP.2013.6738363
URL : https://hal.archives-ouvertes.fr/hal-01436223
Visually Favorable Tone-Mapping With High Compression Performance in Bit-Depth Scalable Video Coding, IEEE Transactions on Multimedia, vol.15, issue.7, 2013. ,
DOI : 10.1109/TMM.2013.2266633
BBCs Response to CfE for HDR Video Coding (Category 3a), Tech. Rep. M36249, ISO/IEC JTC1/SC29/WG11, 2015. ,
Technicolor's Response to CfE for HDR and WCG (category 1) -Single Layer HDR Video Coding with SDR Backward Compatibility, Tech. Rep. M36263, ISO/IEC JTC1/SC29/WG11, 2015. ,
Elements of Information Theory, 2006. ,
Source Coding: Part I of Fundamentals of Source and Video Coding, Foundations and Trends?? in Signal Processing, vol.4, issue.1-2, 2011. ,
DOI : 10.1561/2000000010
HDR Image Gallery ,
High dynamic range image examples ,
