Boundary Nevanlinna-Pick interpolation with prescribed peak points. Application to impedance matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2017
We study a generalized Nevanlinna Pick interpolation problem on the half-plane for rational functions of prescribed degree, where peak points are imposed and interpolation conditions may lie on the real axis. This generalizes previous work by T. Giorgiou, C. Byrnes, A Lindquist and A. Megretski. The problem is motivated by the issue of broadband matching in electronics and microwave system design. We prove existence and uniqueness of a solution by differential-topological techniques. The approach is put to work numerically on a real example, using a continuation method.
Baratchart_Olivi_Seyfert_17.pdf (348.63 Ko) Télécharger le fichier
hal-01377782 , version 1 (07-10-2016)
hal-01377782 , version 2 (06-01-2017)
Laurent Baratchart, Martine Olivi, Fabien Seyfert. Boundary Nevanlinna-Pick interpolation with prescribed peak points. Application to impedance matching. SIAM Journal on Mathematical Analysis, 2017, ⟨10.1137/16M1085577⟩. ⟨hal-01377782v2⟩
Collections
INRIA INRIA2
322 Consultations
301 Téléchargements
