New interface
Journal articles
A Powell-Sabin finite element scheme for partial differential equations
Abstract : In this paper are analyzed finite element methods based on Powell-Sabin splines, for the solution of partial differential equations in two dimensions. PS splines are piecewise quadratic polynomials defined on a triangulation of the domain, and exhibit a global C 1 continuity. Critical issues when dealing with PS splines, and described in this work, are the construction of the shape functions and the imposition of the boundary conditions. The PS finite element method is used at first to solve an elliptic problem describing plasma equilibrium in a tokamak. Finally, a transient convective problem is also considered, and a stabilized formulation is presented.
Complete list of metadata
https://hal.inria.fr/hal-01377903
Contributor : Herve Guillard Connect in order to contact the contributor
Submitted on : Friday, October 7, 2016 - 7:42:23 PM
Last modification on : Thursday, August 4, 2022 - 4:58:36 PM
Links full text
Identifiers
Citation
Giorgio Giorgiani, Hervé Guillard, Boniface Nkonga. A Powell-Sabin finite element scheme for partial differential equations . ESAIM: Proceedings, 2016, 53, pp.64-76. ⟨10.1051/proc/201653005⟩. ⟨hal-01377903⟩
Share
Metrics
Record views
355
