The OPTLS Protocol and TLS 1.3
We present the OPTLS key-exchange protocol, its design, rationale and cryptographic analysis. OPTLS design has been motivated by the ongoing work in the TLS working group of the IETF for specifying TLS 1.3, the next-generation TLS protocol. The latter effort is intended to revamp the security of TLS that has been shown inadequate in many instances as well as to add new security and functional features. The main additions that influence the cryptographic design of TLS 1.3 (hence also of OPTLS) are a new "0-RTT requirement" (0-RTT stands for "zero round trip time") to allow clients that have previously retrieved or cached the public key of the server to send protected data already in the first flow of the protocol, making perfect forward secrecy (PFS) a mandatory requirement, and moving to elliptic curves as the main cryptographic basis for the protocol (for performance and security reasons). Accommodating these requirements calls for moving away from the RSA-centric design of TLS in favor of a protocol based on Diffie-Hellman techniques. OPTLS offers a simple design framework that supports all the above requirements from the protocol with a uniform and modular logic that helps in the specification, analysis, performance optimization, and future maintenance of the protocol. The current (draft) specification of TLS 1.3 builds upon the OPTLS framework as a basis for the cryptographic core of the handshake protocol adapting the different modes of OPTLS to the TLS 1.3 context.
