Leakage-Resilient Cryptography from Minimal Assumptions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptology Année : 2016
We present new constructions of leakage-resilient cryptosystems, which remain provably secure even if the attacker learns some arbitrary partial information about their internal secret-key. For any polynomial ℓ, we can instantiate these schemes so as to tolerate up to ℓ bits of leakage. While there has been much prior work constructing such leakage-resilient cryptosystems under concrete number-theoretic and algebraic assumptions, we present the first schemes under general and minimal assumptions. In particular, we construct: Leakage-resilient public-key encryption from any standard public-key encryption. Leakage-resilient weak pseudorandom functions, symmetric-key encryption, and message-authentication codes from any one-way function. These are the first constructions of leakage-resilient symmetric-key primitives that do not rely on public-key assumptions. We also get the first constructions of leakage-resilient public-key encryption from “search assumptions,” such as the hardness of factoring or CDH. Although our schemes can tolerate arbitrarily large amounts of leakage, the tolerated rate of leakage (defined as the ratio of leakage amount to key size) is rather poor in comparison with prior results under specific assumptions. As a building block of independent interest, we study a notion of weak hash-proof systems in the public-key and symmetric-key settings. While these inherit some of the interesting security properties of standard hash-proof systems, we can instantiate them under general assumptions.
hal-01378199 , version 1 (09-10-2016)
Carmit Hazay, Adriana López-Alt, Hoeteck Wee, Daniel Wichs. Leakage-Resilient Cryptography from Minimal Assumptions. Journal of Cryptology, 2016, 29 (3), pp.514-551. ⟨10.1007/s00145-015-9200-x⟩. ⟨hal-01378199⟩
195 Consultations
0 Téléchargements
