Verification of intense precipitation forecasts from single models and ensemble prediction systems, Nonlinear Processes in Geophysics, vol.8, issue.6, 2001. ,
DOI : 10.5194/npg-8-401-2001
URL : https://hal.archives-ouvertes.fr/hal-00331059
Tracking Closed Curves with Non-linear Stochastic Filters, Conf. on Scale Space and Variational Methods (SSVM'09), pp.576-587, 2009. ,
DOI : 10.1007/3-540-48236-9_13
URL : https://hal.archives-ouvertes.fr/tel-00763157
Stochastic Level Set Dynamics to Track Closed Curves Through Image Data, Journal of Mathematical Imaging and Vision, vol.127, issue.3, pp.296-316 ,
DOI : 10.1007/s10851-013-0464-1
URL : https://hal.archives-ouvertes.fr/hal-00854420
2011 : Some Issues and results on the EnKF and particule filters for meteorological models, Chaotic Systems : Theory and Applications-C. H, 2015. ,
Sensitivity of Several Performance Measures to Displacement Error, Bias, and Event Frequency, Weather and Forecasting, vol.21, issue.4, pp.636-648, 2006. ,
DOI : 10.1175/WAF933.1
ensemble forecasts by inexpensive techniques, Meteorol. Z, vol.22, pp.49-59 ,
On a measure of divergence between two statistical populations defined by their probability distributions, Bulletin of the Calcutta Mathematical Society, vol.35, pp.99-109, 1943. ,
2012 : Impact of stochastic physics in a convection-permitting ensemble ,
2015 : Sensitivities of the AROME ensemble to initial and surface perturbations during HyMeX, Quart. J. Roy. Meteor. Soc ,
Wavelets and Field Forecast Verification, Monthly Weather Review, vol.125, issue.6, pp.1329-1341, 1997. ,
DOI : 10.1175/1520-0493(1997)125<1329:WAFFV>2.0.CO;2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.363.8689
Verification against precipitation observations of a high density network what did we learn ? Intl. Verification Methods Workshop, pp.15-17, 2004. ,
Thunderstorm Strike Probability Nowcasting, Journal of Atmospheric and Oceanic Technology, vol.27, issue.1, pp.79-93, 2010. ,
DOI : 10.1175/2009JTECHA1279.1
Object-Based Verification of Precipitation Forecasts. Part I: Methodology and Application to Mesoscale Rain Areas, Monthly Weather Review, vol.134, issue.7, pp.1772-1784, 2006. ,
DOI : 10.1175/MWR3145.1
Feynman-Kac Formulae. Genealogical and Interacting Particle Systems with Applications, Probability and its Applications, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00410165
Fuzzy verification of high-resolution gridded forecasts: a review and proposed framework, Meteorological Applications, vol.105, issue.1, pp.51-64, 2008. ,
DOI : 10.1002/met.25
Verification of precipitation in weather systems: determination of systematic errors, Journal of Hydrology, vol.239, issue.1-4, pp.179-202, 2000. ,
DOI : 10.1016/S0022-1694(00)00343-7
A Displacement-Based Error Measure Applied in a Regional Ensemble Forecasting System, Monthly Weather Review, vol.135, issue.9, 2007. ,
DOI : 10.1175/MWR3457.1
A Displacement and Amplitude Score Employing an Optical Flow Technique, Weather and Forecasting, vol.24, issue.5, pp.1297-1308, 2009. ,
DOI : 10.1175/2009WAF2222247.1
Cluster analysis for verification of precipitation fields, Wea. Forecasting, pp.824-838, 2006. ,
Cluster Analysis for Object-Oriented Verification of Fields: A Variation, Monthly Weather Review, vol.136, issue.3, pp.1013-1025, 2008. ,
DOI : 10.1175/2007MWR1994.1
Mesoscale Verification Using Meteorological Composites, Monthly Weather Review, vol.132, issue.4, pp.941-955, 2004. ,
DOI : 10.1175/1520-0493(2004)132<0941:MVUMC>2.0.CO;2
Stochastic differential equations, An Introduction with Applications, 2003. ,
Fronts Propagating with Curvature-Dependent Speed : Algorithms Based on, 1988. ,
Stochastic Integration for the Heterogeneous Correlation Modeling Using a Diffusion Equation, Monthly Weather Review, vol.138, issue.8, pp.3356-3365, 2010. ,
DOI : 10.1175/2010MWR3239.1
A Variational Technique for Time Consistent Tracking of Curves and Motion, Journal of Mathematical Imaging and Vision, vol.28, issue.1, pp.81-103, 2008. ,
DOI : 10.1007/s10851-008-0069-2
URL : https://hal.archives-ouvertes.fr/hal-00596154
2015 : Comparison of initial perturbation methods for ensemble prediction at convective scale ,
Application of a Bayesian weighting for short-range lagged ensemble forecasting at the convective scale, Quarterly Journal of the Royal Meteorological Society, vol.60, issue.687, pp.459-468, 2015. ,
DOI : 10.1002/qj.2366
Scale-Selective Verification of Rainfall Accumulations from High-Resolution Forecasts of Convective Events, Monthly Weather Review, vol.136, issue.1, pp.78-97, 2008. ,
DOI : 10.1175/2007MWR2123.1
Level set methods : an act of violence evolving interfaces in geometry, fluid mechanics, computer vision and materials sciences, 1996. ,
The AROME-France Convective-Scale Operational Model, Monthly Weather Review, vol.139, issue.3, pp.976-991, 2011. ,
DOI : 10.1175/2010MWR3425.1
Large displacement optical flow computation without warping, Proc. International Conference on Computer Vision, 2009. ,
Particle Filtering in Geophysical Systems, Monthly Weather Review, vol.137, issue.12, pp.4089-4114, 2009. ,
DOI : 10.1175/2009MWR2835.1
SAL???A Novel Quality Measure for the Verification of Quantitative Precipitation Forecasts, Monthly Weather Review, vol.136, issue.11, pp.4470-4487, 2008. ,
DOI : 10.1175/2008MWR2415.1
Point and areal validation of forecast precipitation fields, Meteorological Applications, vol.105, issue.01, pp.11-20, 2006. ,
DOI : 10.1017/S1350482705001921
URL : https://hal.archives-ouvertes.fr/insu-00386553
Space-time rainfall organization and its role in validating quantitative precipitation forecasts, Journal of Geophysical Research: Atmospheres, vol.104, issue.D16, pp.10129-10146, 2000. ,
DOI : 10.1029/1999JD901087
