Algorithm Selector and Prescheduler in the ICON challenge - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2) , (2) , (2, 3)
1
2
3
Algorithm portfolios are known to offer robust performances, efficiently overcoming the weakness of every single algorithm on some particular problem instances. Two complementary approaches to get the best out of an algorithm portfolio is to achieve algorithm selection (AS), and to define a scheduler, sequentially launching a few algorithms on a limited computational budget each. The presented Algorithm Selector And Prescheduler system relies on the joint optimization of a pre-scheduler and a per instance AS, selecting an algorithm well-suited to the problem instance at hand. ASAP has been thoroughly evaluated against the state-of-the-art during the ICON challenge for algorithm selection, receiving an honourable mention. Its evaluation on several combinatorial optimization benchmarks exposes surprisingly good results of the simple heuristics used; some extensions thereof are presented and discussed in the paper.
META16_V1.pdf (340 Ko) Télécharger le fichier
Dates and versions
hal-01378745 , version 1 (10-10-2016)
Attribution - ShareAlike - CC BY 4.0
Identifiers
  • HAL Id : hal-01378745 , version 1
Cite
François Gonard, Marc Schoenauer, Michèle Sebag. Algorithm Selector and Prescheduler in the ICON challenge. META 2016 - International Conference on Metaheuristics and Nature Inspired Computing, Oct 2016, Marrakech, Morocco. ⟨hal-01378745⟩
781 View
316 Download
Share
