Journal articles
Model updating techniques for damage detection in concrete beam using optical fiber strain measurement device
Abstract : The article aims at detecting and quantifying early structural damages using deterministic and probabilistic model updating techniques. To achieve this purpose, local information in a form of optical strain measurement is employed. The strategy consists in updating physical parameters associated to damages, such as Young’s modulus, in order to minimize the gap between the numerical strain obtained from finite element solves and the strain sensor outputs. Generally, the damage estimation is an ill-posed inverse problem, and hence requires regularization. Herein, three model updating techniques are considered involving different type of regularization: classical Tikhonov regularization, Constitutive Relation Error based updating method and Bayesian approach. An illustration of these three approaches is proposed for localizing and quantifying an early damage in a real 8 meter post-tensioned concrete beam. Numerical results show that all the methods properly localize the damaged area and give similar estimation of the damage level
Document type :
Journal articles
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01379214
Contributor : Laurent Mevel <>
Submitted on : Friday, December 16, 2016 - 11:28:42 AM
Last modification on : Monday, July 5, 2021 - 9:48:08 AM
Long-term archiving on: : Monday, March 20, 2017 - 5:27:25 PM
File
article_REHAB_draft.pdf
Identifiers
Citation
Julien Waeytens, Bojana Rosić, Pierre-Etienne Charbonnel, Erick Merliot, Dominique Siegert, et al.. Model updating techniques for damage detection in concrete beam using optical fiber strain measurement device. Engineering Structures, Elsevier, 2016, ⟨10.1016/j.engstruct.2016.08.004⟩. ⟨hal-01379214⟩
Share
Metrics
Record views
694
Files downloads
510
