ReDyAl: A Dynamic Recommendation Algorithm based on Linked Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Web of Data is an interconnected global dataspace in which discovering resources related to a given resource and recommend relevant ones is still an open research area. This work describes a new recommendation algorithm based on structured data published on the Web (Linked Data). The algorithm exploits existing relationships between resources by dynamically analyzing both the categories to which they belong to and their explicit references to other resources. A user study conducted to evaluate the algorithm showed that our algorithm provides more novel recommendations than other state-of-the-art algorithms and keeps a satisfying prediction accuracy. The algorithm has been applied in a mobile application to recommend movies by relying on DBpedia (the Linked Data version of Wikipedia), although it could be applied to other datasets on the Web of Data.
main_acm.pdf (366.6 Ko) Télécharger le fichier
hal-01379996 , version 1 (12-10-2016)
  • HAL Id : hal-01379996 , version 1
Iacopo Vagliano, Cristhian Figueroa, Oscar Rodríguez Rocha, Marco Torchiano, Catherine Faron Zucker, et al.. ReDyAl: A Dynamic Recommendation Algorithm based on Linked Data. RecSys 2016 - 3rd Workshop on New Trends in Content-Based Recommender Systems co-located with ACM Conference on Recommender Systems, Sep 2016, Boston, United States. ⟨hal-01379996⟩
610 Consultations
201 Téléchargements
