Abstract : The problem of forecasting conditional probabilities of the next event given the past is considered
in a general probabilistic setting. Given an arbitrary (large, uncountable) set C of predictors,
we would like to construct a single predictor that performs asymptotically as well as the
best predictor in C, on any data. Here we show that there are sets C for which such predictors exist,
but none of them is a Bayesian predictor with a prior concentrated on C.
In other words, there is a predictor with sublinear regret, but every Bayesian predictor must have a linear regret. This negative finding is in sharp contrast with previous results
that establish the opposite for the case when one of the predictors in C achieves asymptotically vanishing error.
In such a case, if there is a predictor that achieves asymptotically vanishing error for any measure in C, then there is
a Bayesian predictor that also has this property, and whose prior is concentrated on (a countable subset of) C.
