Estimation of Round-off Errors in OpenMP Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It is crucial to control round-off error propagation in numerical simulations, because they can significantly affect computed results, especially in parallel codes like OpenMP ones. In this paper, we present a new version of the CADNA library that enables the numerical validation of OpenMP codes. With a reasonable cost in terms of execution time, it enables one to estimate which digits in computed results are affected by round-off errors and to detect numerical instabilities that may occur during the execution. The interest of this new OpenMP-enabled CADNA version is shown on various applications, along with performance results on multi-core and many-core (Intel Xeon Phi) architectures.
Eberhart-OpenMP-2016.pdf (353.13 Ko) Télécharger le fichier
hal-01380131 , version 1 (12-10-2016)
Pacôme Eberhart, Julien Brajard, Pierre Fortin, Fabienne Jézéquel. Estimation of Round-off Errors in OpenMP Codes. IWOMP 2016 - 12th International Workshop on OpenMP, Riken AICS, Oct 2016, Nara, Japan. pp.3-16, ⟨10.1007/978-3-319-45550-1_1⟩. ⟨hal-01380131⟩
456 Consultations
680 Téléchargements
