Modeling Pointing Tasks in Mouse-Based Human-Computer Interactions
Pointing is a basic gesture performed by any user during human-computer interaction. It consists in covering a distance to select a target via the cursor in a graphical user interface (e.g. a computer mouse movement to select a menu element). In this work, a dynamic model is proposed to describe the cursor motion during the pointing task. The model design is based on experimental data for pointing with a mouse. The obtained model has switched dynamics, which corresponds well to the state of the art accepted in the human-computer interaction community. The conditions of the model stability are established. The presented model can be further used for the improvement of user performance during pointing tasks.
Automatique / Robotique
