Inferring Sequences Produced by a Linear Congruential Generator on Elliptic Curves Using Coppersmith's Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We analyze the security of the Elliptic Curve Linear Con-gruential Generator (EC-LCG). We show that this generator is insecure if sufficiently many bits are output at each iteration. In 2007, Gutierrez and Ibeas showed that this generator is insecure given a certain amount of most significant bits of some consecutive values of the sequence. Using the Coppersmith's methods, we are able to improve their security bounds.
inferring LCG final version cocoon.pdf (393.29 Ko) Télécharger le fichier
hal-01381658 , version 1 (14-10-2016)
Thierry Mefenza. Inferring Sequences Produced by a Linear Congruential Generator on Elliptic Curves Using Coppersmith's Methods. COCOON 2016, Aug 2016, Ho Chi Minh City, Vietnam. pp.12, ⟨10.1007/978-3-319-42634-1_24⟩. ⟨hal-01381658⟩
132 Consultations
396 Téléchargements
