On the Impact of Advance Reservations for Energy-Aware Provisioning of Bare-Metal Cloud Resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work investigates factors that can impact the elasticity of bare-metal resources. We analyse data from a real bare-metal deployment system to build a deployment time model, which is used to evaluate how provisioning time impacts the reservation of bare-metal resources. Climate/Blazar, a reservation framework designed for OpenStack, is discussed. Simulation results show that reservations can help reduce the time to deliver a provisioned cluster to its customer while achieving energy savings similar to those of strategies that switch-off idle resources.
cnsm2016.pdf (2.46 Mo) Télécharger le fichier
hal-01382662 , version 1 (17-10-2016)
  • HAL Id : hal-01382662 , version 1
Marcos Dias de Assuncao, Laurent Lefèvre, Francois Rossigneux. On the Impact of Advance Reservations for Energy-Aware Provisioning of Bare-Metal Cloud Resources. CNSM 2016, Oct 2016, Montreal, Canada. ⟨hal-01382662⟩
284 Consultations
133 Téléchargements
