Using Fractional Calculus for Cooperative Car-Following Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Cooperative Adaptive Cruise Control (CACC) is one of the most promising aiding systems to improve traffic flow in highways. When it comes to design a proper control algorithm, robustness against non-modeled dynamics and noise plays a key role not only for improving controller performance but also for increasing the ability of handling heterogeneous vehicle strings. This paper proposes a fractional order controller that is able to deal with non-modeled dynamics whereas keeping simplicity and a low computational cost. System robustness and string stability responses are analyzed for a string of six vehicles, showing a good performance.
ITSC16_ACCFOC.pdf (750.68 Ko) Télécharger le fichier
hal-01382821 , version 1 (17-10-2016)
  • HAL Id : hal-01382821 , version 1
Carlos Flores, Vicente Milanés, Fawzi Nashashibi. Using Fractional Calculus for Cooperative Car-Following Control. Intelligent Transportation Systems Conference 2016, IEEE, Nov 2016, Rio de Janeiro, Brazil. ⟨hal-01382821⟩
150 Consultations
510 Téléchargements
