Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Multi-Object Tracking of Pedestrian Driven by Context
Abstract : The characteristics like density of objects, their contrast with respect to surrounding background, their occlu-sion level and many more describe the context of the scene. The variation of the context represents ambiguous task to be solved by tracker. In this paper we present a new long term tracking framework boosted by context around each track-let. The framework works by first learning the database of optimal tracker parameters for various context offline. During the testing, the context surrounding each tracklet is extracted and match against database to select best tracker parameters. The tracker parameters are tuned for each tracklet in the scene to highlight its discrimination with respect to surrounding context rather than tuning the parameters for whole scene. The proposed framework is trained on 9 public video sequences and tested on 3 unseen sets. It outperforms the state-of-art pedestrian trackers in scenarios of motion changes, appearance changes and occlusion of objects.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01383186
Contributor : NGUYEN Thi Lan Anh Connect in order to contact the contributor
Submitted on : Friday, December 9, 2016 - 1:27:58 PM
Last modification on : Saturday, June 25, 2022 - 11:23:51 PM
Long-term archiving on: : Monday, March 20, 2017 - 8:49:52 PM
File
avss_2016.pdf
Identifiers
  • HAL Id : hal-01383186, version 1
Collections
Citation
Thi Lan Anh Nguyen, Francois Bremond, Jana Trojanova. Multi-Object Tracking of Pedestrian Driven by Context. Advance Video and Signal-based Surveillance, IEEE, Aug 2016, Colorado Springs, United States. ⟨hal-01383186⟩
Share
Metrics
Record views
155
Files downloads
115
