Research and Application Analysis of Feature Binding Mechanism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to recognize the object of the external world, brain need to integrate the information of different cortical areas, then form a complete world. And binding problem study on a process to percept a complete object by integrating information, which scattering on different cortical areas. As a central problem of cognitive science and neuroscience, the concept of feature binding is becoming to the focus of consciousness argument. At the beginning of this paper, we introduced the concept, characteristics and theory source of feature binding. And according to the main theoretical research methods of this mechanism, combining the latest advance at home and abroad, we made a systematical review of the research situation of feature binding problem applying in perceptual learning. At last, we pointed out the key point of the further study, which may be refined research of bundled brain mechanism on different cognition process and systematical study of general bundled brain mechanism.
978-3-662-44980-6_15_Chapter.pdf (173.58 Ko) Télécharger le fichier
hal-01383326 , version 1 (18-10-2016)
Paternité
Youzhen Han, Shifei Ding. Research and Application Analysis of Feature Binding Mechanism. 8th International Conference on Intelligent Information Processing (IIP), Oct 2014, Hangzhou, China. pp.133-140, ⟨10.1007/978-3-662-44980-6_15⟩. ⟨hal-01383326⟩
46 Consultations
122 Téléchargements
