Does parietal cortex contribute to feature binding?, Neuropsychologia, vol.37, issue.9, pp.999-1004, 1999. ,
DOI : 10.1016/S0028-3932(98)00160-2
Feature binding signals in visual cortex, Journal of Vision, vol.10, issue.7, pp.2010-96 ,
DOI : 10.1167/10.7.96
et al Neural synchrony correlates with surface segregation rules, Nature, vol.405, issue.6787, pp.685-689, 2000. ,
The feature-binding problem is an ill-posed problem, Trends in cognitive sciences, vol.16, issue.6, pp.2012-317 ,
Temporal binding and the neural correlates of sensory awareness, Trends in Cognitive Sciences, vol.5, issue.1, pp.16-25, 2001. ,
DOI : 10.1016/S1364-6613(00)01568-0
et al Posterior parietal cortex and the filtering of distractors, Proceedings of the National Academy of Sciences, vol.100, issue.7, pp.2003-4263 ,
Synchronization of oscillatory responses in visual cortex correlates with perception in interocular rivalry, Proceedings of the National Academy of Sciences, vol.94, issue.23, pp.12699-12704, 1997. ,
DOI : 10.1073/pnas.94.23.12699
Multi-focus image fusion using pulse coupled neural network, Pattern Recognition Letters, vol.28, issue.9, pp.1123-1132, 2007. ,
DOI : 10.1016/j.patrec.2007.01.013
affinity propagation algorithm to build context-aware learning system analysis, pp.2012-2058 ,
et al Effects of incidental and intentional feature binding on recognition: a behavioural and PET activation study, Neuropsychologia, vol.40, issue.2, p.2002 ,
The intrinsic electrophysiological properties of mammalian neurons: insights into central nervous system function, Science, vol.242, issue.4886, pp.1654-1664, 1988. ,
DOI : 10.1126/science.3059497
fMRI evidence of age-related hippocampal dysfunction in feature binding in working memory, Cognitive Brain Research, vol.10, issue.1-2, pp.197-206, 2000. ,
DOI : 10.1016/S0926-6410(00)00029-X
et al Integration of diverse information in working memory within the frontal lobe, Nature Neuroscience, vol.3, issue.1, pp.85-90, 2000. ,
DOI : 10.1038/71156
Hierarchical models of object recognition in cortex, Nature neuroscience, vol.2, issue.11, pp.1019-1025, 1999. ,
Visual Feature Integration and the Temporal Correlation Hypothesis, Annual Review of Neuroscience, vol.18, issue.1, pp.555-586, 1995. ,
DOI : 10.1146/annurev.ne.18.030195.003011
et al Stimulus specificity of phase-locked and non-phase-locked 40 Hz visual responses in human, The Journal of Neuroscience, vol.16, issue.13, pp.4240-4249, 1996. ,
et al Induced ?-band activity during the delay of a visual short-term memory task in humans, The Journal of Neuroscience, vol.18, issue.11, pp.4244-4254, 1998. ,
The Correlation Theory of Brain Function, 1994. ,
DOI : 10.1007/978-1-4612-4320-5_2
Solving the binding problem of the brain with bi-directional functional connectivity, Neural Networks, vol.14, issue.4-5, pp.395-406, 2001. ,
DOI : 10.1016/S0893-6080(01)00036-3
New Spiking Cortical Model for Invariant Texture Retrieval and Image Processing, IEEE Transactions on Neural Networks, vol.20, issue.12, pp.1980-1986, 2009. ,
DOI : 10.1109/TNN.2009.2030585
