Z. J. Zha, X. S. Hua, and T. Mei, Joint multi-label multi-instance learning for image classification, Pattern Recognition, pp.1-8, 2008.
Z. Zhou and M. Zhang, Multi-instance multi-label learning with application to scene classi-fication, Advances in Neural Information Processing Systems, pp.1609-1616, 2007.
Z. Zhou and M. Zhang, Multi-instance multi-label learning, Artificial Intelligence, vol.176, issue.1, pp.2291-2320
DOI : 10.1016/j.artint.2011.10.002
O. Maron and A. Ratan, Multiple-Instance Learning for Natural Scene Classification, Proceedings of ICML, pp.341-349, 1998.
C. Yang and T. Lozano-perez, Image database retrieval with multiple-instance learning techniques, Proceedings of 16th International Conference on Data Engineering (Cat. No.00CB37073), pp.233-243, 2000.
DOI : 10.1109/ICDE.2000.839416
T. Kohonen, Self-organizing maps, 2001.
Y. Jiang, K. J. Chen, and Z. Zhou, SOM Based Image Segmentation, Rough Sets, Fuzzy Sets, Data Mining, and Granular Computing, pp.640-643, 2003.
DOI : 10.1007/3-540-39205-X_107
D. J. Marceau, P. J. Howarth, and J. Dubois, Evaluation of the grey-level cooccurrence matrix method for land-cover classification using SPOT imagery, IEEE Transactions on Geoscience and Remote Sensing, issue.4, pp.28-513, 1990.
C. Böhm and F. Krebs, The k-Nearest Neighbour Join: Turbo Charging the KDD Process, Knowledge and Information Systems, vol.joins, issue.6, pp.728-749, 2004.
DOI : 10.1007/s10115-003-0122-9
C. Mian-shu, Y. Shu-yuan, and Z. Zhi-jie, Multi-points diverse density learning algorithm and its application in image retrieval, Journal of jilin university: engineering science, issue.5, pp.41-1456, 2011.
O. Maron and T. Lozano-pérez, A framework for multiple-instance learning Advances in neural information processing systems, pp.570-576, 1998.
Z. Dai-hongbin, Z. Ling, and . Zhihua, A Multi-Instance based approach to image retrieval, Journal of pattern recognition and artificial intelligence, vol.19, issue.2, pp.179-185, 2006.
L. Chengyang, Image database retrieval with multiple-instance learning techniques, Proceedings of the 16th International Conference on Data Engineering, 2000.
