Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Dynamic Programming-Based Lifetime Reliability Optimization in Networks-on-Chip
Abstract : Technology scaling leads to the reliability issue as a primary concern in Networks-on-Chip (NoC) design. Due to routing algorithms, some routers may age much faster than others, which become a bottleneck for system lifetime. In this chapter, lifetime is modeled as a resource consumed over time. A metric lifetime budget is associated with each router, indicating the maximum allowed workload for current period. Since the heterogeneity in router lifetime reliability has strong correlation with the routing algorithm, we define a problem to optimize the lifetime by routing packets along the path with maximum lifetime budgets. A dynamic programming-based lifetime-aware routing algorithm is proposed to optimize the lifetime distribution of routers. The dynamic programming network approach is employed to solve this problem with linear complexity. The experimental results show that the lifetime-aware routing has around 20 %, 45 %, 55 % minimal MTTF improvement than XY routing, NoP routing, and Oddeven routing, respectively.
Document type :
Conference papers
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01383724
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, October 19, 2016 - 10:45:24 AM
Last modification on : Thursday, March 5, 2020 - 5:40:20 PM
File
371768_1_En_1_Chapter.pdf
Identifiers
Citation
Liang Wang, Xiaohang Wang, Terrence Mak. Dynamic Programming-Based Lifetime Reliability Optimization in Networks-on-Chip. 22th IFIP/IEEE International Conference on Very Large Scale Integration - System on a Chip (VLSI-SoC 2014), Oct 2014, Playa del Carmen, Mexico. pp.1-20, ⟨10.1007/978-3-319-25279-7_1⟩. ⟨hal-01383724⟩
Share
Metrics
Record views
126
Files downloads
57
