Dynamic On-Chip Thermal Optimization for Three-Dimensional Networks-On-Chip, The Computer Journal, vol.56, issue.6, pp.756-770, 2013. ,
DOI : 10.1093/comjnl/bxs135
Efficient microarchitecture for network-on-chip routers, 2012. ,
Processor: A 64-Core SoC with Mesh Interconnect, 2008 IEEE International Solid-State Circuits Conference, Digest of Technical Papers, pp.88-598, 2008. ,
DOI : 10.1109/ISSCC.2008.4523070/mm1
Dynamic Programming, 1957. ,
An MILP-based aging-aware routing algorithm for NoCs, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.326-331, 2012. ,
DOI : 10.1109/DATE.2012.6176489
Towards graceful aging degradation in NoCs through an adaptive routing algorithm, Proceedings of the 49th Annual Design Automation Conference on, DAC '12, pp.382-391, 2012. ,
DOI : 10.1145/2228360.2228429
The PARSEC benchmark suite, Proceedings of the 17th international conference on Parallel architectures and compilation techniques, PACT '08, pp.72-81, 2008. ,
DOI : 10.1145/1454115.1454128
HAT: Heterogeneous Adaptive Throttling for On-Chip Networks, 2012 IEEE 24th International Symposium on Computer Architecture and High Performance Computing, pp.9-18, 2012. ,
DOI : 10.1109/SBAC-PAD.2012.44
The odd-even turn model for adaptive routing, IEEE Transactions on Parallel and Distributed Systems, vol.11, issue.7, pp.729-738, 2000. ,
DOI : 10.1109/71.877831
Deadlock-Free Message Routing in Multiprocessor Interconnection Networks, IEEE Transactions on Computers, vol.36, issue.5, pp.547-553, 1987. ,
DOI : 10.1109/TC.1987.1676939
Reliability-Driven Task Mapping for Lifetime Extension of Networks-on-Chip Based Multiprocessor Systems, Design, Automation & Test in Europe Conference & Exhibition (DATE), 2013, pp.689-694, 2013. ,
DOI : 10.7873/DATE.2013.149
Temperature-Aware DVFS for Hard Real-Time Applications on Multicore Processors, IEEE Transactions on Computers, vol.61, issue.10, pp.1484-1494, 2012. ,
DOI : 10.1109/TC.2011.156
Lifetime improvement through runtime wear-based task mapping, Proceedings of the eighth IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis, CODES+ISSS '12, pp.13-22, 2012. ,
DOI : 10.1145/2380445.2380455
HotSpot: a compact thermal modeling methodology for early-stage VLSI design, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, pp.501-513, 2006. ,
DOI : 10.1109/TVLSI.2006.876103
ORION 2.0: A Power-Area Simulator for Interconnection Networks, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, pp.191-196, 2012. ,
DOI : 10.1109/TVLSI.2010.2091686
Use it or lose it, Proceedings of the 46th Annual IEEE/ACM International Symposium on Microarchitecture, MICRO-46, pp.136-147, 2013. ,
DOI : 10.1145/2540708.2540721
Silicon odometer: An on-chip reliability monitor for measuring frequency degradation of digital circuits, Proceedings of IEEE Symposium on VLSI Circuits, pp.122-123, 2007. ,
Interconnect Lifetime Prediction for Reliability-Aware Systems, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.15, issue.2, pp.159-172, 2007. ,
DOI : 10.1109/TVLSI.2007.893578
Adaptive Routing in Network-on-Chips Using a Dynamic-Programming Network, IEEE Transactions on Industrial Electronics, vol.58, issue.8, pp.3701-3716, 2011. ,
DOI : 10.1109/TIE.2010.2081953
A DP-network for optimal dynamic routing in network-on-chip, Proceedings of the 7th IEEE/ACM international conference on Hardware/software codesign and system synthesis, CODES+ISSS '09, pp.119-128, 2009. ,
DOI : 10.1145/1629435.1629452
Workload and user experience-aware dynamic reliability management in multicore processors, Proceedings of the 50th Annual Design Automation Conference on, DAC '13, pp.1-6, 2013. ,
DOI : 10.1145/2463209.2488735
Thermal Balancing Policy for Multiprocessor Stream Computing Platforms, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.28, issue.12, pp.1870-1882, 2009. ,
DOI : 10.1109/TCAD.2009.2032372
Metrics for Architecture-Level Lifetime Reliability Analysis, ISPASS 2008, IEEE International Symposium on Performance Analysis of Systems and software, pp.202-212, 2008. ,
DOI : 10.1109/ISPASS.2008.4510752
Dynamic Thermal Management Under Soft Thermal Constraints, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, pp.2045-2054, 2013. ,
DOI : 10.1109/TVLSI.2012.2227854
The case for lifetime reliabilityaware microprocessors, Proceedings of the 31st Annual International Symposium on Computer Architecture (ISCA), pp.276-285, 2004. ,
The impact of technology scaling on lifetime reliability, International Conference on Dependable Systems and Networks, 2004, pp.177-186, 2004. ,
DOI : 10.1109/DSN.2004.1311888
Dynamic programming-based lifetime aware adaptive routing algorithm for Network-on-Chip, 2014 22nd International Conference on Very Large Scale Integration (VLSI-SoC), pp.1-6, 2014. ,
DOI : 10.1109/VLSI-SoC.2014.7004156
A low cost, high performance dynamic-programming-based adaptive power allocation scheme for many-core architectures in the dark silicon era, The 11th IEEE Symposium on Embedded Systems for Real-time Multimedia, pp.61-67, 2013. ,
DOI : 10.1109/ESTIMedia.2013.6704504
On selftuning networks-on-chip for dynamic network-flow dominance adaptation, Proceedings of 2013 Seventh IEEE/ACM International Symposium on Networks on Chip (NoCS), pp.1-8, 2013. ,
Fine-grained runtime power budgeting for networks-on-chip, The 20th Asia and South Pacific Design Automation Conference, pp.160-165, 2015. ,
DOI : 10.1109/ASPDAC.2015.7058998
The splash-2 programs: characterization and methodological considerations, Proceedings of the 22nd Annual International Symposium on Computer Architecture (ISCA), pp.24-36, 1995. ,
Reliable multiprocessor system-on-chip synthesis, Proceedings of the 5th IEEE/ACM international conference on Hardware/software codesign and system synthesis , CODES+ISSS '07, pp.239-244, 2007. ,
DOI : 10.1145/1289816.1289874
Process variation and temperature-aware reliability management, Proceedings of Design, Automation Test in Europe Conference Exhibition (DATE), pp.580-585, 2010. ,
On multicast for dynamic and irregular on-chip networks using dynamic programming method, Proceedings of the Sixth International Workshop on Network on Chip Architectures, NoCArc '13, pp.17-22, 2013. ,
DOI : 10.1145/2536522.2536529
