Constrained PRFs for Unbounded Inputs with Short Keys - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A constrained pseudorandom function (CPRF) F:K×X→Y for a family T of subsets of X is a function where for any key k∈K and set S∈T one can efficiently compute a short constrained key k_S, which allows to evaluate F(k,⋅) on all inputs x∈S, while the outputs on all inputs x∉S look random even given k_S. Abusalah et al. recently constructed the first constrained PRF for inputs of arbitrary length whose sets S are decided by Turing machines. They use their CPRF to build broadcast encryption and the first ID-based non-interactive key exchange for an unbounded number of users. Their constrained keys are obfuscated circuits and are therefore large. In this work we drastically reduce the key size and define a constrained key for a Turing machine M as a short signature on M. For this, we introduce a new signature primitive with constrained signing keys that let one only sign certain messages, while forging a signature on others is hard even when knowing the coins for key generation.
Fichier non déposé
hal-01384375 , version 1 (19-10-2016)
Hamza Abusalah, Georg Fuchsbauer. Constrained PRFs for Unbounded Inputs with Short Keys. Applied Cryptography and Network Security - 14th International Conference, ACNS 2016, Jun 2016, Guildford, United Kingdom. ⟨10.1007/978-3-319-39555-5_24⟩. ⟨hal-01384375⟩
103 Consultations
0 Téléchargements
