HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Practical Round-Optimal Blind Signatures in the Standard Model from Weaker Assumptions
Abstract : At Crypto'15 Fuchsbauer, Hanser and Slamanig (FHS) presented the first standard-model construction of efficient round-optimal blind signatures that does not require complexity leveraging. It is conceptually simple and builds on the primitive of structure-preserving signatures on equivalence classes (SPS-EQ). FHS prove the unforgeability of their scheme assuming EUF-CMA security of the SPS-EQ scheme and hardness of a version of the DH inversion problem. Blindness under adversarially chosen keys is proven under an interactive variant of the DDH assumption. We propose a variant of their scheme whose blindness can be proven under a non-interactive assumption, namely a variant of the bilinear DDH assumption. We moreover prove its unforgeability assuming only unforgeability of the underlying SPS-EQ but no additional assumptions as needed for the FHS scheme.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01384381
Contributor : Georg Fuchsbauer Connect in order to contact the contributor
Submitted on : Wednesday, October 19, 2016 - 6:00:32 PM
Last modification on : Thursday, March 17, 2022 - 10:08:52 AM
Identifiers
Collections
Citation
Georg Fuchsbauer, Christian Hanser, Chethan Kamath, Daniel Slamanig. Practical Round-Optimal Blind Signatures in the Standard Model from Weaker Assumptions. Security and Cryptography for Networks - 10th International Conference, SCN 2016, Aug 2016, Amalfi, Italy. ⟨10.1007/978-3-319-44618-9_21⟩. ⟨hal-01384381⟩
Share
Metrics
Record views
63
