Parameterization and reconstruction from 3D scattered points based on neural network and PDE techniques, IEEE Transactions on Visualization and Computer Graphics, vol.7, issue.1, pp.1-16, 2001. ,
DOI : 10.1109/2945.910817
Geometric Processing for Design and Manufacturing, SIAM, 1992. ,
Curve and Surface Fitting with Splines, 1993. ,
Curves and surfaces for CAGD, 2002. ,
Extending Neural Networks for B-Spline Surface Reconstruction, Lectures Notes in Computer Science, vol.2330, pp.305-314, 2002. ,
DOI : 10.1007/3-540-46080-2_32
Efficient particle swarm optimization approach for data fitting with free knot -splines, Computer-Aided Design, vol.43, issue.12, pp.1683-1692, 2011. ,
DOI : 10.1016/j.cad.2011.07.010
Particle swarm optimization for non-uniform rational B-spline surface reconstruction from clouds of 3D data points, Information Sciences, vol.192, issue.1, pp.174-192, 2012. ,
DOI : 10.1016/j.ins.2010.11.007
A new iterative mutually coupled hybrid GA???PSO approach for curve fitting in manufacturing, Applied Soft Computing, vol.13, issue.3, pp.1491-1504, 2013. ,
DOI : 10.1016/j.asoc.2012.05.030
Firefly Algorithm for Polynomial B??zier Surface Parameterization, Journal of Applied Mathematics, vol.2, issue.2, p.9, 2013. ,
DOI : 10.1155/2012/467631
From nonlinear optimization to convex optimization through firefly algorithm and indirect approach with applications to CAD/CAM. The Scientific World Journal, p.10, 2013. ,
Firefly Algorithm for Explicit B-Spline Curve Fitting to Data Points, Mathematical Problems in Engineering, vol.19, issue.6, 2013. ,
DOI : 10.1214/aos/1176344136
Cuckoo search with Lévy flights for weighted Bayesian energy functional optimization in global-support curve data fitting. The Scientific World Journal, p.11, 2014. ,
New memetic self-adaptive firefly algorithm for continuous optimization, International Journal of Bio-Inspired Computation ,
Immunological-based Approach for Accurate Fitting of 3D Noisy Data Points with B??zier Surfaces, Proc. of Int. Conference on Comp. Science-ICCS'2013, Procedia Computer Science, pp.50-59, 2013. ,
DOI : 10.1016/j.procs.2013.05.168
Elitist clonal selection algorithm for optimal choice of free knots in B-spline data fitting, Applied Soft Computing, vol.26, pp.90-106, 2015. ,
DOI : 10.1016/j.asoc.2014.09.030
Iterative two-step genetic-algorithm-based method for efficient polynomial B-spline surface reconstruction, Information Sciences, vol.182, issue.1, pp.56-76, 2012. ,
DOI : 10.1016/j.ins.2010.09.031
Neural network approach to the reconstruction of freeform surfaces for reverse engineering, Computer-Aided Design, vol.27, issue.1, pp.59-64, 1995. ,
DOI : 10.1016/0010-4485(95)90753-3
Numerical control of kohonen neural network for scattered data approximation, Numerical Algorithms, vol.19, issue.1-3, pp.175-186, 2005. ,
DOI : 10.1007/s11075-004-3628-7
Functional networks for B-spline surface reconstruction, Future Generation Computer Systems, vol.20, issue.8, pp.1337-1353, 2004. ,
DOI : 10.1016/j.future.2004.05.025
Hybrid Functional-Neural Approach for Surface Reconstruction, Mathematical Problems in Engineering, vol.54, issue.3, p.13, 2014. ,
DOI : 10.1016/j.cag.2005.08.006
Fitting B-spline Curves by Least Squares Support Vector Machines, 2005 International Conference on Neural Networks and Brain, pp.905-909, 2005. ,
DOI : 10.1109/ICNNB.2005.1614767
Adaptive knot placement in B-spline curve approximation, Computer-Aided Design, vol.37, issue.8, pp.791-797, 2005. ,
DOI : 10.1016/j.cad.2004.09.008
Simulated Annealing Algorithm for Bezier Curve Approximation, 2014 International Conference on Cyberworlds, pp.182-189, 2014. ,
DOI : 10.1109/CW.2014.33
An error-bounded approximate method for representing planar curves in B-splines, Computer Aided Geometric Design, vol.21, issue.5, pp.479-497, 2004. ,
DOI : 10.1016/j.cagd.2004.03.003
-spline curve fitting based on adaptive curve refinement using dominant points, Computer-Aided Design, vol.39, issue.6, pp.439-451, 2007. ,
DOI : 10.1016/j.cad.2006.12.006
URL : https://hal.archives-ouvertes.fr/hal-00458708
Shape Interrogation for Computer Aided Design and Manufacturing, 2002. ,
DOI : 10.1007/978-3-642-04074-0
Industrial geometry: recent advances and applications in CAD, Computer-Aided Design, vol.37, issue.7, pp.751-766, 2005. ,
DOI : 10.1016/j.cad.2004.08.013
Curve fitting by splines in one variable (editor): Numerical approximation to functions and data, 1970. ,
Directed Artificial Bat Algorithm (DABA) - A new bio-inspired algorithm, 2013 International Conference on Advances in Computing, Communications and Informatics (ICACCI), pp.1241-1246, 2013. ,
DOI : 10.1109/ICACCI.2013.6637355
Capturing outline of fonts using genetic algorithm and splines, Proceedings Fifth International Conference on Information Visualisation, pp.738-743, 2001. ,
DOI : 10.1109/IV.2001.942138
Fitting B-spline curves to point clouds by curvature-based squared distance minimization, ACM Transactions on Graphics, vol.25, issue.2, pp.214-238, 2006. ,
DOI : 10.1145/1138450.1138453
A New Metaheuristic Bat-Inspired Algorithm, Nature Inspired Cooperative Strategies for Optimization Studies in Computational Intelligence, pp.65-74, 2010. ,
DOI : 10.1007/978-3-642-12538-6_6
Bat algorithm for multi-objective optimisation, International Journal of Bio-Inspired Computation, vol.3, issue.5, pp.267-274, 2011. ,
DOI : 10.1504/IJBIC.2011.042259
Bat algorithm: a novel approach for global engineering optimization, Engineering Computations, vol.29, issue.5, pp.464-483, 2012. ,
DOI : 10.1108/02644401211235834
Bat algorithm: literature review and applications, International Journal of Bio-Inspired Computation, vol.5, issue.3, pp.141-149, 2013. ,
DOI : 10.1504/IJBIC.2013.055093
Data fitting with a spline using a real-coded genetic algorithm, Computer-Aided Design, vol.35, issue.8, pp.751-760, 2003. ,
DOI : 10.1016/S0010-4485(03)00006-X
Adaptive knot placement using a GMM-based continuous optimization algorithm in B-spline curve approximation, Computer-Aided Design, vol.43, issue.6, pp.598-604, 2011. ,
DOI : 10.1016/j.cad.2011.01.015
