Abstract : Identifying variant combination association with disease is a bioinformatics challenge. This problem can be solved by discriminative pattern mining that use statistical function to evaluate the significance of individual biological patterns. There is a wide range of such measures. However, selecting an appropriate measure as well as a suitable threshold in some specific practical situations is a difficult task. In this article, we propose to use the skypattern technique which allows combinations of measures to be used to evaluate the importance of variant combinations without having to select a given measure and a fixed threshold. Experiments on several real variant datasets demonstrate that the skypattern method effectively identifies the risk variant combinations related to diseases.
https://hal.inria.fr/hal-01385614
Contributeur : Dominique Lavenier
Soumis le : vendredi 21 octobre 2016 - 16:41:34
Dernière modification le : mercredi 11 avril 2018 - 02:01:30
