BIM and PLM: Comparing and Learning from Changes to Professional Practice Across Sectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
J. R. Jupp
  • Fonction : Auteur
  • PersonId : 991258
M. Nepal
  • Fonction : Auteur
  • PersonId : 991259
This paper explores the effects of PLM and BIM on professional practice. It draws on existing literature documenting the experiences of both communities of practice to explain shifts in professional boundaries. A review of case study based literature compares the nature of changes triggered by PLM and BIM relative to the new activities, roles/responsibilities and knowledge competencies, and supply chain relationships. The paper synthesises these changes and reflects PLM and BIM experiences against each other so as to contrast the continuing evolution of professional practice and lessons learned.
978-3-662-45937-9_5_Chapter.pdf (1011.81 Ko) Télécharger le fichier
hal-01386474 , version 1 (24-10-2016)
Paternité
J. R. Jupp, M. Nepal. BIM and PLM: Comparing and Learning from Changes to Professional Practice Across Sectors. 11th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2014, Yokohama, Japan. pp.41-50, ⟨10.1007/978-3-662-45937-9_5⟩. ⟨hal-01386474⟩
92 Consultations
737 Téléchargements
