Large and moderate deviations for the left random walk on GL d (R) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Using martingale methods, we obtain some upper bounds for large and moderate deviations of products of independent and identically distributed elements of GL d (R). We investigate all the possible moment conditions, from super-exponential moments to weak moments of order p > 1, to get a complete picture of the situation. We also prove a moderate deviation principle under an appropriate tail condition.
deviations20juillet.pdf (206.84 Ko) Télécharger le fichier
hal-01386519 , version 1 (24-10-2016)
Christophe Cuny, Jérôme Dedecker, Florence Merlevède. Large and moderate deviations for the left random walk on GL d (R). 2016. ⟨hal-01386519⟩
128 Consultations
170 Téléchargements
