Abstract : A high accuracy edge measurement method of edges of components using point cloud data by 3D laser scanner is proposed in this paper. The proposed method consists of two parts: method for shape measurement of edges by using points of side faces of the components and method for length measurement of edges by attaching the 3D targets. At the experiments with a surface plate and a curved shell plate, the results give suggestions for having possibility of applying this proposed method for actual shipbuilding components.
https://hal.inria.fr/hal-01386548 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, October 24, 2016 - 11:53:54 AM Last modification on : Monday, May 17, 2021 - 12:00:04 PM
