Stiffness rendering on soft tangible devices controlled through inverse FEM simulation - Archive ouverte HAL Access content directly
Conference Papers Year :
Haptic rendering of soft bodies is essential in medical simulations of procedures such as surgery or palpation. The most commonly used approach is to recreate the sense of touch using a specific design and control of a robotic arm. In this paper, we propose a new approach, based on soft-robotics technology. We create a tangible deformable device that allows users to " touch " soft tissues and perceive mechanical material properties, in a realistic manner. The device is able to dynamically provide user touch with different stiffness perceptions, thanks to actuators placed at the boundaries. We introduce a control algorithm, based on inverse Finite Element Analysis, which controls the actuators in order to recreate a desired stiffness that corresponds to the contact with soft tissues in the virtual environment. The approach uses antagonistic actuation principle to create a wide range of stiffness. We validate our algorithm and demonstrate the method using prototypes based on simple mechanisms.
IROS_stiffness_interface.pdf (2.66 Mo) Télécharger le fichier
Dates and versions
hal-01386787 , version 1 (24-10-2016)
Identifiers
  • HAL Id : hal-01386787 , version 1
Cite
Frédérick Largillière, Eulalie Coevoet, Mario Sanz Lopez, Laurent Grisoni, Christian Duriez. Stiffness rendering on soft tangible devices controlled through inverse FEM simulation. International Conference on Intelligent Robots and Systems - IROS 2016, Oct 2016, Daejeon, South Korea. ⟨hal-01386787⟩
301 View
348 Download
Share
