New interface
Reports (Research report)
Distributed Adaptive Routing in Communication Networks
Abstract : In this report, we present a new adaptive multi-flow routing algorithm to select end- to-end paths in packet-switched networks. This algorithm provides provable optimality guarantees in the following game theoretic sense: The network configuration converges to a configuration arbitrarily close to a pure Nash equilibrium. In this context, a Nash equilibrium is a configuration in which no flow can improve its end-to-end delay by changing its network path. This algorithm has several robustness properties making it suitable for real-life usage: it is robust to measurement errors, outdated information and clocks desynchronization. Furthermore, it is only based on local information and only takes local decisions, making it suitable for a distributed implementation. Our SDN-based proof-of-concept is built as an Openflow controller. We set up an emulation platform based on Mininet to test the behavior of our proof-of-concept implementation in several scenarios. Although real-world conditions do not conform exactly to the theoretical model, all experiments exhibit satisfying behavior, in accordance with the theoretical predictions.
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01386832
Contributor : Bruno Gaujal Connect in order to contact the contributor
Submitted on : Monday, October 24, 2016 - 6:45:37 PM
Last modification on : Wednesday, October 26, 2022 - 8:14:53 AM
File
RR-8959.pdf
Identifiers
  • HAL Id : hal-01386832, version 1
Citation
Baptiste Jonglez, Bruno Gaujal. Distributed Adaptive Routing in Communication Networks. [Research Report] RR-8959, Inria; Univ. Grenoble Alpes. 2016, pp.25. ⟨hal-01386832⟩
Share
Metrics
Record views
227
Files downloads
458
