Pointer Disambiguation via Strict Inequalities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The design and implementation of static analyses that disambiguate pointers has been a focus of research since the early days of compiler construction. One of the challenges that arise in this context is the analysis of languages that support pointer arithmetics, such as C, C++ and assembly dialects. This paper contributes to solve this challenge. We start from an obvious, yet unexplored, observation: if a pointer is strictly less than another, they cannot alias. Motivated by this remark, we use the abstract interpretation framework to build strict less-than relations between pointers. To this end, we construct a program representation that bestows the Static Single Information (SSI) property onto our dataflow analysis. SSI gives us an efficient sparse algorithm, which, once seen as a form of abstract interpretation, is correct by construction. We have implemented our static analysis in LLVM. It runs in time linear on the number of program variables, and, depending on the benchmark, it can be as much as six times more precise than the pointer disambiguation techniques already in place in that compiler.
CGO17_AuthorVersion.pdf (1.22 Mo) Télécharger le fichier
hal-01387031 , version 1 (22-12-2016)
  • HAL Id : hal-01387031 , version 1
Maroua Maalej, Vitor Paisante, Ramos Pedro, Laure Gonnord, Fernando Pereira. Pointer Disambiguation via Strict Inequalities. Code Generation and Optimisation , Feb 2017, Austin, United States. pp.134-147. ⟨hal-01387031⟩
273 Consultations
448 Téléchargements
