Surface Nanostructure of Hevea Brasiliensis Natural Rubber Latex Particles, Colloid. Surface. A: Physicochemical and Engineering Aspects, pp.1-3, 2011. ,
Historical Development of the World Rubber Industry, Dev. Crop Sci, vol.23, pp.1-25, 1992. ,
DOI : 10.1016/B978-0-444-88329-2.50007-6
Latex as a Comfort Layer http://www.factory-beds-direct.co.uk/latex-as-acomfort-layer (2014) (accessed on 21, 2014. ,
Characterization of associated proteins and phospholipids in natural rubber latex, Journal of Bioscience and Bioengineering, vol.111, issue.6, pp.628-634, 2011. ,
DOI : 10.1016/j.jbiosc.2011.01.013
Framework for computing machining parameter settings in CNC machines: an industrial case study, International Journal of Computational Systems Engineering, vol.2, issue.1, 2014. ,
DOI : 10.1504/IJCSYSE.2015.067753
Quality Engineering using Robust Design, 1989. ,
Small and medium enterprises project finance: identifying optimum settings of controllable factor, International Journal of Applied Decision Sciences, vol.7, issue.2, pp.136-150, 2014. ,
DOI : 10.1504/IJADS.2014.060327
Use of Robust Design Technique in Job Shop Manufacturing: A Case Study of Die-Sinking Electro Discharge Machining, Int. J. Perform. Eng, vol.10, issue.2, pp.153-160, 2014. ,
Quality Engineering through Design Optimization, Conf. Record GLOBECOM 84 Meeting, 1984. ,
DOI : 10.1007/978-1-4684-1472-1_5
Taguchi methods and expert systems in fabrication design, International Journal of Pressure Vessels and Piping, vol.53, issue.1, pp.47-61, 1992. ,
DOI : 10.1016/0308-0161(93)90103-Z
Application of Taguchi Method in the Optimization of Injection Moulding Parameters for Manufacturing Products from Plastic Blend, International Journal of Engineering and Technology, vol.2, issue.6, pp.1793-8236, 2010. ,
DOI : 10.7763/IJET.2010.V2.184
