Key Performance Indicators Used as Measurement Parameter for Plant-Wide Feedback Loops - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Charlotta Johnsson
  • Fonction : Auteur
  • PersonId : 991405
Feedback is a fundamental concept in automatic control. Feedback loops are used extensively in industrial applications today and there are work-procedures for designing traditional single parameter control loops. In the work procedure it is important to select control-parameters, manipulated parameters and control-strategies. A similar work-procedure could also be used for designing plant-wide control feedback loops. Key performance Indicators is thus an important concept since they can be used as control-parameters. In this paper an analogy between the single-loop and plant-wide approach is discussed, and key performance indicators from the new international standard ISO 22400 are presented.
978-3-662-44733-8_12_Chapter.pdf (214.55 Ko) Télécharger le fichier
hal-01387153 , version 1 (25-10-2016)
Paternité
Charlotta Johnsson. Key Performance Indicators Used as Measurement Parameter for Plant-Wide Feedback Loops. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.91-99, ⟨10.1007/978-3-662-44733-8_12⟩. ⟨hal-01387153⟩
74 Consultations
1181 Téléchargements
