Abstract : The energy efficiency of manufacturing systems represents a topic of huge interest for the management of innovative production plants. In this paper, a production cell based on three operating machines has been taken into account. In particular, each machine has an independent lubrication system whose lubricant is cooled by a centralized cooling system, while the lubrication fluid temperatures must be maintained inside known upper and lower bounds, and the controller of the centralized cooling system has to minimize the cooling power. In order to control the lubrication and cooling processes, a Model Predictive Controller (MPC) has been designed, synthetized, implemented and simulated.The main advantage of the proposed algorithm consists in the possibility to directly consider the temperature limits together with the maximum bound of the cooling power directly into the optimization problem. This means that the control action is computed using the a-priori knowledge of these bounds, resulting in better temperature profiles then those obtained with standard controllers, e.g. with saturated Proportional, Integral, Derivative (PID) ones.
https://hal.inria.fr/hal-01387157
Contributor : Hal Ifip <>
Submitted on : Tuesday, October 25, 2016 - 11:19:16 AM Last modification on : Thursday, March 5, 2020 - 4:44:15 PM
Andrea Cataldo, Andrea Perizzato, Riccardo Scattolini. Management of a Production Cell Lubrication System with Model Predictive Control. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.131-138, ⟨10.1007/978-3-662-44733-8_17⟩. ⟨hal-01387157⟩
