Decouttere Improvement of Human-Plant Interactivity via Industrial Cloud-Based Supervisory Control and Data Acquisition System, p.83 ,
A Theoretical and Practical Synthesis, 108 Farhad Norouzilame Ralph Riedel, and Jessica Bruch An Engineer-To-Order Mass Customization Development Framework, p.116 ,
124 Patrick Badets, VéroniquePilnì ere, and Christophe Merlo Management of a Production Cell Lubrication System with Model Predictive Control, p.131 ,
Scattolini Selecting Theoretical Models for IT and Supply Chain through a, p.139 ,
Hybrid Method for Solving Buffer Sizing and Inspection Stations Allocation ,
Part III XVII Integrating Real-Time Analytics and Continuous Performance Management in Smart Manufacturing Systems, 175 Senthilkumaran Kumaraguru, Boonserm (Serm) Kulvatunyou, and Katherine C. Morris Supply Uncertainty in Food Processing Supply Chain: Sources and Coping Strategies, p.183 ,
192 Michael Quade, David Jentsch, and Egon Mueller Framework for Resilient Production Systems, Matthias Heinicke Achieving Responsiveness in Small and Medium-Sized Enterprises through Assemble To Order Strategy, p.208 ,
Evaluation in Physical Asset Management: Benefits and Limitations for Industrial Adoption, p.216 ,
Jessica Bruch, and Mats Jackson A Method to Create a Process Reference Model Adapted to Heterogeneous Organizations, p.232 ,
Urbani Implementation of Lean Project Planning: A Knowledge Transfer Perspective, p.248 ,
Techniques for Mechanization of In-Service Inspection Planning Process Chandima Ratnayake XVIII Table of Contents ? Part III Paths for Modularization: Modularization for Flexible Structural Platform for Boats, 272 Bjørnar Henriksen and Carl Christian Røstad Flow Disturbance Analysis in Workshops with High Reworks Rate . . . . . 280 ,
André Thomas, Patrick Charpentier, and Thomas Brault A Strategic Approach for Automation Technology Initiatives Selection, p.288 ,
Resource as Evolutionary Determinant of International Manufacturing Joint Venture's Growth Performance, p.304 ,
Joergensen Managing Uncertainty in Innovative Design: Balancing Control and Flexibility, p.313 ,
Claude Baron, and Emmanuel Caillaud Motivations and Challenges for Engineer-to-Order Companies Moving toward Mass Customization, p.320 ,
Taps Decentralized Approach for Efficient Simulation of Devs Models, p.336 ,
and Nicolas Perry Assessing the Role of Plants in International Manufacturing Networks: A Tool to Monitor the Strategic Alignment, p.360 ,
and Alessandro Fontana Table of Contents ? Part III XIX Reducing the Research Space of Possible Order Release Dates for Multi-level Assembly Systems under Stochastic Lead Times, p.368 ,
Alexandre Dolgui, and Dash Wu Layout Design by Integration of Multi-agent Based Simulation and Optimization: Application to Underground Shopping Streets, p.375 ,
Tomomi Nonaka, and Shun Nogami Future of ERP: Challenges and Opportunities in the SaaS-era, p.383 ,
Requirements for a Value Stream Mapping in Make-To-Order Environments, 391 Christoph Koch and Hermann Lödding Enacting Innovation within Collaborative-Driven SOA Providers Networks, p.399 ,
409 Youssef Bouanan, Merouane Bouhamidi El Alaoui, Gregory Zacharewicz, and Bruno Vallespir Toward Human-Centric Factories: Requirements and Design Aspects of a Worker-Centric Job, p.417 ,
Edan The Effect of the Existence of Defective Items in Assembly Operations, p.449 ,
Reliability Driven Standardization of Mechanical Seals for Petrochemical, p.455 ,
Felix Friemann, and Paul Schönsleben Case Studies Designing an Engineer-To-Order Performance Measurement System: A Case Study, p.473 ,
Supply Network Complexity: An Approach in a Global Aeronautic Industry in, p.489 ,
Reis Supply Chain Quality Management in Agribusiness: An Approach of Quality Management Systems in Food Supply Chains, p.497 ,
Rogério Monteiro, and José Benedito Sacomano Development of the Auto Parts Industry in, p.505 ,
Vendrametto Integration of Decision Support Modules to Identify the Priority of Risk of Failure in Topside Piping Equipment: An Industrial Case Study from the Ratnayake CART for Supply Chain Simulation Models Reduction: Application to a, Sawmill Internal Supply Chain, p.530 ,
Johannes Linzbach, and Christoph Herrmann Table of Contents ? Part III XXI Integrating Aspects of Supply Chain Design into the Global Sourcing Process ? Insights from the Automotive Industry, p.555 ,
Marco Taisch, and Fred Voorhorst Taxonomy of Engineer-To-Order Companies, p.579 ,
