New interface
Preprints, Working Papers, ...
Optimal Control Theory and the Swimming Mechanism of the Copepod Zooplankton
Abstract : In this article, the model of swimming at low Reynolds number introduced by D. Takagi (2015) to analyze the displacement of an abundant variety of zooplankton is used as a testbed to analyze the motion of symmetric microswimmers in the framework of optimal control theory assuming that the motion occurs minimizing the energy dissipated by the fluid drag forces in relation with the concept of efficiency of a stroke. The maximum principle is used to compute periodic controls candidates as minimizing controls and is a decisive tool combined with appropriate numerical simulations using indirect optimal control schemes to determine the most efficient stroke compared with standard computations using Stokes theorem and curvature control. Also the concept of graded approximations in SR-geometry is used to evaluate strokes with small amplitudes providing a fixed displacement and minimizing the dissipated energy.
Document type :
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01387443
Contributor : Jérémy Rouot Connect in order to contact the contributor
Submitted on : Tuesday, October 25, 2016 - 3:37:43 PM
Last modification on : Friday, November 25, 2022 - 10:12:06 AM
File
copepod-20102016.pdf
Identifiers
  • HAL Id : hal-01387443, version 1
Citation
Piernicola Bettiol, Bernard Bonnard, Alice Nolot, Jérémy Rouot. Optimal Control Theory and the Swimming Mechanism of the Copepod Zooplankton. 2016. ⟨hal-01387443⟩
Share
Metrics
Record views
231
Files downloads
54
