Toyota production system and Kanban system Materialization of just-in-time and respect-for-human system, International Journal of Production Research, vol.15, issue.6, pp.553-564, 1977. ,
DOI : 10.1080/00207547708943149
Supply chain simulation tools and techniques: a survey, International Journal of Simulation and Process Modelling, vol.1, issue.1/2, 2005. ,
DOI : 10.1504/IJSPM.2005.007116
HS3CM - A New Formulation for Supply Chain Modeling, SAE Technical Paper Series, 2011. ,
DOI : 10.4271/2011-36-0068
Optimal design of the auto parts supply chain for JIT operations: Sequential bifurcation factor screening and multi-response surface methodology, European Journal of Operational Research, vol.236, issue.2, pp.664-676, 2014. ,
DOI : 10.1016/j.ejor.2013.11.015
Caracteriza????o do sistema de coleta programada de pe??as, milk run, RAE eletr??nica, vol.1, issue.1, pp.jan-jun, 2002. ,
DOI : 10.1590/S1676-56482002000100010
Formaliza????o da log??stica de suprimentos: caso das montadoras e fornecedores da ind??stria automotiva Brasileira, Produ????o, vol.20, issue.2, pp.186-199, 2010. ,
DOI : 10.1590/S0103-65132010005000020
URL : http://www.scielo.br/pdf/prod/v20n2/aop_200804034.pdf
Relationship Between Assemblers and Suppliers: Theoretical Models and Case Studies in the Brazilian Auto Industry, Gest. Prod, issue.18 2, pp.237-250, 2011. ,
Negociação e Administração de Conflitos, 2012. ,
Goods transport in large European cities: Difficult to organize, difficult to modernize, Transportation Research Part A: Policy and Practice, vol.41, issue.3, pp.280-285, 2007. ,
DOI : 10.1016/j.tra.2006.05.005
The Milk RunR: A Load Factor Paradox with Economic and Environmental Implications for Urban Freight Transport, Transportation Research Part A, vol.51, pp.56-62, 2013. ,
Trends of energy efficiency in Finnish road freight transport 1995???2009 and forecast to 2016, Energy Policy, vol.38, issue.12, pp.7676-7686, 2010. ,
DOI : 10.1016/j.enpol.2010.08.010
