P. Sasikumar and G. Kannan, Issues in reverse supply chains, part I: end-of-life product recovery and inventory management - an overview, International Journal of Sustainable Engineering, vol.1, issue.3, pp.154-172, 2008.
DOI : 10.1080/19397030802433860
G. Yang, Z. Wang, and X. Li, The optimization of the closed-loop supply chain network, Transportation Research Part E: Logistics and Transportation Review, vol.45, issue.1, pp.16-28, 2009.
DOI : 10.1016/j.tre.2008.02.007
M. A. Ilgin and S. M. Gupta, Performance Improvement Potential of Sensor Embedded Products in Environmental Supply Chains. Resources, Conservation and Recycling, pp.580-592, 2011.
F. T. Altekin, L. Kandiller, and N. E. Ozdemirel, Profit-oriented disassembly-line balancing, International Journal of Production Research, vol.5, issue.10, pp.2675-2693, 2008.
DOI : 10.1287/mnsc.11.7.727
M. Boudia, S. Dauzere-peres, C. Prins, and M. A. Louly, Integrated optimization of production and distribution for several products, 2006 International Conference on Service Systems and Service Management, pp.272-277, 2006.
DOI : 10.1109/ICSSSM.2006.320625
M. Boudia, M. A. Louly, and C. Prins, A reactive GRASP and path relinking for a combined production???distribution problem, Computers & Operations Research, vol.34, issue.11, pp.3402-3419, 2007.
DOI : 10.1016/j.cor.2006.02.005
M. Boudia and . Prins, A memetic algorithm with dynamic population management for an integrated production???distribution problem, European Journal of Operational Research, vol.195, issue.3, pp.703-715, 2009.
DOI : 10.1016/j.ejor.2007.07.034
J. F. Bard and N. Nananukul, A branch-and-price algorithm for an integrated production and inventory routing problem, Computers & Operations Research, vol.37, issue.12, pp.2202-2217, 2010.
DOI : 10.1016/j.cor.2010.03.010
A. Dolgui and J. Proth, Supply Chain Engineering: Useful Methods and Techniques, 2010.
DOI : 10.1007/978-1-84996-017-5
URL : https://hal.archives-ouvertes.fr/emse-00675734
M. L. Bentaha, O. Batta¨?abatta¨?a, and A. Dolgui, A decomposition method for stochastic partial disassembly line balancing with profit maximization, 2013 IEEE International Conference on Automation Science and Engineering (CASE), pp.404-409, 2013.
DOI : 10.1109/CoASE.2013.6654016
URL : https://hal.archives-ouvertes.fr/emse-00903586
M. L. Bentaha, O. Batta¨?abatta¨?a, and A. Dolgui, A sample average approximation method for disassembly line balancing problem under uncertainty, Computers & Operations Research, vol.51, pp.111-122, 2014.
DOI : 10.1016/j.cor.2014.05.006
URL : https://hal.archives-ouvertes.fr/emse-01083333
M. L. Bentaha, O. Batta¨?abatta¨?a, and A. Dolgui, L-shaped Algorithm for Stochastic Disassembly Line Balancing Problem, 7th IFAC Conference on Modelling, Management , and Control, pp.407-411, 2013.
DOI : 10.3182/20130619-3-RU-3018.00500
URL : https://hal.archives-ouvertes.fr/emse-00881583
M. L. Bentaha, O. Batta¨?abatta¨?a, and A. Dolgui, A Stochastic Formulation of the Disassembly Line Balancing Problem, APMS 2012. IFIP AICT, pp.397-404, 2013.
DOI : 10.1287/mnsc.32.4.455
URL : https://hal.archives-ouvertes.fr/emse-00904027
M. L. Bentaha, O. Batta¨?abatta¨?a, and A. Dolgui, Chance Constrained Programming Model for Stochastic Profit???Oriented Disassembly Line Balancing in the Presence of Hazardous Parts, APMS 2013. IFIP AICT, pp.103-110, 2013.
DOI : 10.1007/978-3-642-41266-0_13
URL : https://hal.archives-ouvertes.fr/emse-00880909
M. L. Bentaha, O. Batta¨?abatta¨?a, and A. Dolgui, Dealing with Uncertainty in Disassembly Line Design. CIRP Annals -Manufacturing Technology, pp.21-24, 2014.
URL : https://hal.archives-ouvertes.fr/emse-00978385
A. Koc, I. Sabuncuoglu, E. Erel, E. Ozceylan, T. Paksoy et al., Two Exact Formulations for Disassembly Line Balancing Problems with Task Precedence Diagram Construction using An AND/OR Graph Modeling and Optimizing the Integrated Problem of Closed?Loop Supply Chain Network Design and Disassembly Line Balancing . Transportation Research Part E: Logistics and Transportation Review Interactive fuzzy programming approaches to the strategic and tactical planning of a closed-loop supply chain under uncertainty, IIE Transactions. International Journal of Production Research, vol.41, issue.18, pp.866-881, 2009.
A. Shiguemoto and V. A. Armentano, A tabu search procedure for coordinating production, inventory and distribution routing problems, International Transactions in Operational Research, vol.5, issue.2, pp.179-195, 2010.
DOI : 10.1111/j.1475-3995.2009.00741.x
P. A. Varthanan, N. Murugan, and G. M. Kumar, A simulation based heuristic discrete particle swarm algorithm for generating integrated production???distribution plan, Applied Soft Computing, vol.12, issue.9, pp.3034-3050, 2012.
DOI : 10.1016/j.asoc.2012.05.001
A. Gharehyakheh and R. Tavakkoli-moghaddam, A fuzzy solution approach for a multi-objective integrated production-distribution model with multi products and multi periods under uncertainty, Management Science Letters, vol.2, issue.7, pp.2425-2434, 2012.
DOI : 10.5267/j.msl.2012.07.025
