Programming Integrated Surgical Operations and Preventive Maintenance Activities
The operating theatre (OT) represents a significant component of the technical means centre. This facility is the largest cost and revenue centre. To be efficient, it needs an optimal operational pro- gramme, which takes into account maintenance activi- ties and not only surgical operations. To build such a programme, various methods have been used: mixed integer programming (MIP), three classic heuristics for Bin-Packing and a coupling of the first alterna- tive with a stochastic descent (SD). Then we compare the obtained results from generated data.
Informatique [cs]
