Conference papers
Investigation of the directional emissivity of materials using infrared thermography coupled with a periodic excitation
Abstract : This article concerns the determination of the directional emissivity of materials. Several materials (conducting materials or dielectrics) are investigated and the influence of surface roughness is also considered. The experimental method used for the determination is based on the use of a periodic excitation and the recording of the surface temperature variations of the sample using infrared thermography. Several consecutive measurements are performed for emission angles varying from 0° (for the determinat ion of normal emissivity) to 85°. The experimental device developed (SPIDER instrument) is simple compared to existing devices but the variation of directional emissivity is limited to the spectral bandwith of the camera used.
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-01388188
Contributor : Antoine Crinière Connect in order to contact the contributor
Submitted on : Wednesday, October 26, 2016 - 4:04:02 PM
Last modification on : Thursday, January 20, 2022 - 5:29:45 PM
File
031.pdf
Identifiers
Citation
Laurent Ibos, Jean-Pierre Monchau, Vincent Feuillet, Jean Dumoulin, Patrick Ausset, et al.. Investigation of the directional emissivity of materials using infrared thermography coupled with a periodic excitation. QIRT 2016, Jul 2016, Gdańsk Poland. ⟨10.21611/qirt.2016.031⟩. ⟨hal-01388188⟩
Share
Metrics
Record views
177
Files downloads
672
