Similar patterns of patterns of community organization characterize distinct groups of different trophic levels in the plankton of the NW Mediterranean Sea - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biogeosciences Année : 2009
Planktonic populations were sampled over a 4 week period in the NW Mediterranean, at a site subject to little vertical advection during the Dynaproc 2 cruise in 2004. The characteristics of the phytoplankton, the tintinnid community and the zooplankton have recently been described in detail. Based on these studies, we compared the characteristics of 3 well-circumscribed assemblages of different trophic levels: Ceratium of the phytoplankton, herbivorous tintin-nids of the microzooplankton, and large (>500 µm) omnivo-rous and carnivorous copepods of the metazoan zooplankton. In all three groups, diversity as H' or species richness, was less variable than concentration of organisms. Plotting time against species accumulation, the curves approached plateau values for Ceratium spp, tintinnids and large copepods but only a small number of species were consistently present (core species) and these accounted for most of the populations. For Ceratium core species numbered 10, for tintinnids 11 species, and for large copepods, core species numbered 4 during the day and 16 at night. Ceratium, tintinnids and large copepods showed some similar patterns of community structure in terms of species abundance distributions. Ceratium species were distributed in a log-normal pattern. Tintinnid species showed a log-series distribution. Large copepod assemblages were highly dominated with night samples showing much higher abundances and greater species richness than day samples. However, species abundance distributions were similar between day and night and were mostly log-Correspondence to: J. Dolan (dolan@obs-vlfr.fr) normal. The paradox of the plankton, describing phytoplank-ton communities as super-saturated with species, extends to the microzooplankton and zooplankton.
bg-6-431-2009.pdf (1006.04 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01388443 , version 1 (27-10-2016)
Paternité
V. Raybaud, A. Tunin-Ley, M.E. Ritchie, J.R. Dolan. Similar patterns of patterns of community organization characterize distinct groups of different trophic levels in the plankton of the NW Mediterranean Sea. Biogeosciences, 2009, 6, pp.431-438. ⟨10.5194/bg-6-431-2009⟩. ⟨hal-01388443⟩
57 Consultations
68 Téléchargements
