Clique covering of large real-world networks - Archive ouverte HAL Access content directly
Conference Papers Year : 2016
The edge clique covering (ecc) problem deals with discovering a set of (possibly overlapping) cliques in a given network, such that each edge is part of at least one of these cliques. We address the ecc problem from an alternative perspective reconsidering the quality of the cliques found, and proposing more structured criteria with respect to the traditional measures such as minimum number of cliques. In the case of real-world networks, having millions of nodes, such as social networks, the possibility of getting a result is constrained to the running time, which should be linear or almost linear in the size of the network. Our algorithm for finding eccs of large networks has linear-time performance in practice, as our experiments show on real-world networks whose number of nodes ranges from thousands to several millions.
edgeclique.pdf (2.94 Mo) Télécharger le fichier
Dates and versions
hal-01388477 , version 1 (16-06-2017)
Identifiers
Cite
Alessio Conte, Roberto Grossi, Andrea Marino. Clique covering of large real-world networks. 31st Annual ACM Symposium on Applied Computing (SAC 2016), Apr 2016, Pisa, Italy. pp.1134-1139, ⟨10.1145/2851613.2851816⟩. ⟨hal-01388477⟩
Collections
INRIA INRIA2
97 View
103 Download
Share
