Design and Evaluation of Fusion Approach for Combining Brain and Gaze Inputs for Target Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Neuroscience Année : 2016
Gaze-based interfaces and Brain-Computer Interfaces (BCIs) allow for hands-free human–computer interaction. In this paper, we investigate the combination of gaze and BCIs. We propose a novel selection technique for 2D target acquisition based on input fusion. This new approach combines the probabilistic models for each input, in order to better estimate the intent of the user. We evaluated its performance against the existing gaze and brain–computer interaction techniques. Twelve participants took part in our study, in which they had to search and select 2D targets with each of the evaluated techniques. Our fusion-based hybrid interaction technique was found to be more reliable than the previous gaze and BCI hybrid interaction techniques for 10 participants over 12, while being 29% faster on average. However, similarly to what has been observed in hybrid gaze-and-speech interaction, gaze-only interaction technique still provides the best performance. Our results should encourage the use of input fusion, as opposed to sequential interaction, in order to design better hybrid interfaces.
manuscript.pdf (1.67 Mo) Télécharger le fichier
hal-01388528 , version 1 (27-10-2016)
Andéol Évain, Ferran Argelaguet Sanz, Géry Casiez, Nicolas Roussel, Anatole Lécuyer. Design and Evaluation of Fusion Approach for Combining Brain and Gaze Inputs for Target Selection. Frontiers in Neuroscience, 2016, 10 (454), pp.14. ⟨10.3389/fnins.2016.00454⟩. ⟨hal-01388528⟩
335 Consultations
131 Téléchargements
