Prokaryotic evolution and the tree of life are two different things, Biology Direct, vol.4, issue.1, p.34, 2009. ,
DOI : 10.1186/1745-6150-4-34
Neighborhood subtree tolerance graphs, Discrete Applied Mathematics, vol.43, issue.1, pp.13-26, 1993. ,
DOI : 10.1016/0166-218X(93)90165-K
URL : http://doi.org/10.1016/0166-218x(93)90165-k
On leaf powers, 2010. ,
Ptolemaic Graphs and Interval Graphs Are Leaf Powers, LATIN 2008: Theoretical Informatics, pp.479-491, 2008. ,
DOI : 10.1007/978-3-540-78773-0_42
Rooted directed path graphs are leaf powers, Discrete Mathematics, vol.310, issue.4, pp.897-910, 2010. ,
DOI : 10.1016/j.disc.2009.10.006
Structure and linear time recognition of 3-leaf powers, Information Processing Letters, vol.98, issue.4, pp.133-138, 2006. ,
DOI : 10.1016/j.ipl.2006.01.004
A forbidden induced subgraph characterization of distance-hereditary 5-leaf powers, Discrete Mathematics, vol.309, issue.12, pp.3843-3852, 2009. ,
DOI : 10.1016/j.disc.2008.10.025
Exact leaf powers, Theoretical Computer Science, vol.411, issue.31-33, pp.31-332968, 2010. ,
DOI : 10.1016/j.tcs.2010.04.027
Graph Classes: A Survey, Society for Industrial and Applied Mathematics, 1999. ,
DOI : 10.1137/1.9780898719796
Structure and linear-time recognition of 4-leaf powers, ACM Trans. Algorithms, vol.511, issue.1, pp.1-1122, 2008. ,
On k- Versus (k???+???1)-Leaf Powers, Combinatorial Optimization and Applications, pp.171-179, 2008. ,
DOI : 10.1007/978-3-540-85097-7_16
The complete inclusion structure of leaf power classes, Theoretical Computer Science, vol.410, pp.5505-5514, 2009. ,
Pairwise Compatibility Graphs of Caterpillars, The Computer Journal, vol.57, issue.11, pp.1616-1623, 2014. ,
DOI : 10.1093/comjnl/bxt068
URL : http://eprints.adm.unipi.it/2305/1/TR%2D13%2D09.pdf.gz
All Graphs with at Most Seven Vertices are Pairwise Compatibility Graphs, The Computer Journal, vol.56, issue.7, pp.882-886, 2013. ,
DOI : 10.1093/comjnl/bxs087
URL : http://arxiv.org/abs/1202.4631
On pairwise compatibility of some graph (super)classes, 2015. ,
Exploring pairwise compatibility graphs, Theoretical Computer Science, vol.468, pp.23-26, 2013. ,
DOI : 10.1016/j.tcs.2012.11.015
On pairwise compatibility graphs having Dilworth number two, Theoretical Computer Science, vol.524, pp.34-40, 2013. ,
DOI : 10.1016/j.tcs.2013.12.015
On pairwise compatibility graphs having Dilworth number k, Theoretical Computer Science, vol.547, pp.82-89, 2014. ,
DOI : 10.1016/j.tcs.2014.06.024
On pairwise compatibility graphs having Dilworth number two, Theoretical Computer Science, vol.524, pp.34-40, 2014. ,
On Relaxing the Constraints in Pairwise Compatibility Graphs, WALCOM: Algorithms and Computation, pp.124-135, 2012. ,
DOI : 10.1007/978-3-642-28076-4_14
ON THE PAIRWISE COMPATIBILITY PROPERTY OF SOME SUPERCLASSES OF THRESHOLD GRAPHS, Discrete Mathematics, Algorithms and Applications, vol.56, issue.02, p.51360002, 2013. ,
DOI : 10.1007/s12190-008-0204-7
Relating threshold tolerance graphs to other graph classes, Proceedings of the 15th Italian Conference on Theoretical Computer Science, pp.73-79, 2014. ,
The 3-Steiner Root Problem, Lecture Notes in Computer Science, vol.4769, pp.109-120, 2007. ,
DOI : 10.1007/978-3-540-74839-7_11
Computing Phylogenetic Roots with Bounded Degrees and Errors, SIAM Journal on Computing, vol.32, issue.4, pp.864-879, 2003. ,
DOI : 10.1137/S0097539701389154
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.93.6707
Aggregation of Inequalities in Integer Programming, Studies in Integer Programming26] H.N. de Ridder et al. Information System on Graph Classes and their Inclusions(ISGCI), pp.145-162, 1977. ,
DOI : 10.1016/S0167-5060(08)70731-3
A Decomposition Theorem for Partially Ordered Sets, The Annals of Mathematics, vol.51, issue.1, pp.161-166, 1950. ,
DOI : 10.2307/1969503
Error Compensation in Leaf Root Problems, Algorithms and Computation, pp.389-401, 2005. ,
DOI : 10.1007/978-3-540-30551-4_35
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.145.6472
Extending the Tractability Border for Closest Leaf Powers, Lecture Notes in Computer Science, vol.3787, pp.397-408, 2005. ,
DOI : 10.1007/11604686_35
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.297.490
On graphs that are not PCGs, Theoretical Computer Science, 2015. ,
DOI : 10.1007/978-3-642-36065-7_29
Characterizations of strongly chordal graphs, Discrete Mathematics, vol.43, issue.2-3, pp.173-189, 1983. ,
DOI : 10.1016/0012-365X(83)90154-1
Cases in which Parsimony or Compatibility Methods Will be Positively Misleading, Systematic Zoology, vol.27, issue.4, pp.401-410, 1978. ,
DOI : 10.2307/2412923
Split graphs. 8th South?Eastern Conf, Louisiana StateUniv. Baton Rouge, pp.311-315, 1977. ,
A recognition algorithm for the intersection graphs of directed paths in directed trees, Discrete Mathematics, vol.13, issue.3, pp.237-249, 1975. ,
DOI : 10.1016/0012-365X(75)90021-7
Tolerance graphs, Discrete Applied Mathematics, vol.9, issue.2, pp.157-170, 1984. ,
DOI : 10.1016/0166-218X(84)90016-7
The number of caterpillars, Discrete Mathematics, vol.6, issue.4, pp.359-365, 1973. ,
DOI : 10.1016/0012-365X(73)90067-8
NeST graphs, Discrete Applied Mathematics, vol.121, issue.1-3, pp.1-3139, 2002. ,
DOI : 10.1016/S0166-218X(01)00207-4
URL : http://doi.org/10.1016/s0166-218x(01)00207-4
Recognizing $P_4 $-Sparse Graphs in Linear Time, SIAM Journal on Computing, vol.21, issue.2, pp.381-406, 1992. ,
DOI : 10.1137/0221027
Efficient Generation of Uniform Samples from Phylogenetic Trees, Algorithms in Bioinformatics Lecture Notes in Computer Science, vol.2812, pp.177-189, 2003. ,
DOI : 10.1007/978-3-540-39763-2_14
Clanistics: a multi-level perspective for harvesting unrooted gene trees, Trends in Microbiology, vol.18, issue.8, pp.341-347, 2010. ,
DOI : 10.1016/j.tim.2010.03.009
Phylogenetic k-Root and Steiner k-Root, Algorithms and Computation, pp.539-551, 1969. ,
DOI : 10.1007/3-540-40996-3_46
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.36.3974
Threshold graphs and related topics, Annals of Discrete Mathematics, 1995. ,
Pairwise compatibility graphs revisited, 2013 International Conference on Informatics, Electronics and Vision (ICIEV), pp.1-6, 2013. ,
DOI : 10.1109/ICIEV.2013.6572681
A generalization of threshold graphs with tolerance, Congressus Numerantium, vol.55, pp.187-197, 1986. ,
Threshold tolerance graphs, Journal of Graph Theory, vol.2, issue.3, pp.343-362, 1988. ,
DOI : 10.1002/jgt.3190120307
Towards a Characterization of Leaf Powers by Clique Arrangements, SOFSEM 2015: Theory and Practice of Computer Science, pp.364-376, 2015. ,
DOI : 10.1007/978-3-662-46078-8_30
On Graph Powers for Leaf-Labeled Trees, Journal of Algorithms, vol.42, issue.1, pp.69-108, 2002. ,
DOI : 10.1006/jagm.2001.1195
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.37.5320
Uniform sampling from phylogenetic trees. Master Degree -Univ, 2002. ,
Some remarks about leaf roots, Discrete Mathematics, vol.306, issue.13, pp.1456-1461, 2006. ,
DOI : 10.1016/j.disc.2006.03.030
URL : http://doi.org/10.1016/j.disc.2006.03.030
On powers of strongly chordal and circular graphs, Ars Combin, vol.34, pp.147-160, 1992. ,
On graphs that are not pcgs, WALCOM: Algorithms and Computation, pp.310-321, 2013. ,
Triangle-Free Outerplanar 3-Graphs are Pairwise Compatibility Graphs, Journal of Graph Algorithms and Applications, vol.17, issue.2, pp.81-102, 2013. ,
DOI : 10.7155/jgaa.00286
Decomposition of graphical sequences and unigraphs, Discrete Mathematics, vol.220, issue.1-3, pp.201-238, 2000. ,
DOI : 10.1016/S0012-365X(99)00381-7
URL : http://doi.org/10.1016/s0012-365x(99)00381-7
Discovering pairwise compatibility graphs, Discrete Math., Alg. and Appl, vol.2, issue.4, pp.607-624, 2010. ,
Pairwise compatibility graphs, Journal of Applied Mathematics and Computing, vol.29, issue.1, pp.479-503, 2009. ,
