An Optimization Tool for Process Planning and Scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Process planning and scheduling are one of the most important functions to support flexible planning in a manufacture. The planning and scheduling should be solved simultaneously and not sequential for productivity improvements in manufacturing. In this paper, we propose an optimization tool based on genetic algorithm (GA) approach to help person in charge of process planning and scheduling to find the most promising sequence of operations considering a choice of machines on which to perform the operations. Minimizing makespan is the evaluation criteria.
978-3-662-44739-0_54_Chapter.pdf (514.52 Ko) Télécharger le fichier
hal-01388574 , version 1 (27-10-2016)
Paternité
Mathieu Bettwy, Karine Deschinkel, Samuel Gomes. An Optimization Tool for Process Planning and Scheduling. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.443-450, ⟨10.1007/978-3-662-44739-0_54⟩. ⟨hal-01388574⟩
156 Consultations
243 Téléchargements
