New interface
Journal articles
Reduced Regional Cortical Thickness Rate of Change in Donepezil-Treated Subjects With Suspected Prodromal Alzheimer’s Disease
Enrica Cavedo 1 Bruno Dubois 2, 3 Olivier Colliot 3, 4, 5, 6 Simone Lista 2, 3 Bernard Croisile 7 Guy Louis Tisserand 8 Jacques Touchon 9 Alain Bonafe 10 Pierre J. Ousset 11 Olivier Rouaud 12 Fréderic Ricolfi 13 Alain Vighetto 7 Florence Pasquier 14 Samantha Galluzzi 15 Christine Delmaire 16 Mathieu Ceccaldi 17 Nadine Girard 18 Stéphane Lehericy 2, 6 Françoise Duveau 19 Marie Chupin 4 Marie Sarazin 20 Didier Dormont 4, 6 Harald Hampel 3
Abstract : OBJECTIVE: Cortical thinning, previously identified during prodromal stages of Alzheimer's disease (AD), is a "candidate" biomarker implemented in AD clinical therapy trials. We investigated the effect of donepezil treatment on cortical thickness in mild cognitively impaired subjects with the amnestic syndrome of the hippocampal type, a prodromal at-risk group for progression to AD dementia. METHODS: Data were from a longitudinal analysis of a community-based multicenter suspected prodromal AD cohort diagnosed by the Free and Cued Selective Reminding Test (81 donepezil vs 92 placebo) enrolled in a double-blind, randomized, placebo-controlled parallel group design using donepezil (10 mg/day). The study started in November 2006 and concluded in August 2010. All subjects underwent 2 brain structural magnetic resonance imaging (MRI) scans, at baseline and at the end of the trial. Structural MRI images had been processed using the automated pipeline for longitudinal segmentation and surface reconstruction implemented in FreeSurfer. The primary outcome measure of this post hoc study was the annualized percentage change (APC) of cortical thickness. RESULTS: The donepezil group exhibited reduced APC cortical thinning compared to placebo in the rostral anterior cingulate (right: P = .048; left: P = .032), the orbitofrontal (right: P = .012; left: P < .048), and the right inferior frontal (P = .022) cortices and in the right insula (P = .010). These results were not statistically significant after Bonferroni correction likely due to insufficient power for cortical thickness measurements in the study group powered for the predefined hippocampus outcome. CONCLUSIONS: Our findings support the hypothesis that cortical thickness is a reliable candidate surrogate outcome in early predementia AD trials. In addition, donepezil treatment may have an impact on cortical structure/morphology in areas innervated by the medial and lateral cholinergic pathways.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01388951
Contributor : Olivier Colliot Connect in order to contact the contributor
Submitted on : Saturday, November 12, 2016 - 1:41:11 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Thursday, March 16, 2017 - 11:36:04 AM
File
cavedo16_the Journal of Clinic...
Identifiers
Citation
Enrica Cavedo, Bruno Dubois, Olivier Colliot, Simone Lista, Bernard Croisile, et al.. Reduced Regional Cortical Thickness Rate of Change in Donepezil-Treated Subjects With Suspected Prodromal Alzheimer’s Disease. Journal of Clinical Psychiatry, 2016, ⟨10.4088/JCP.15m10413⟩. ⟨hal-01388951⟩
Share
Metrics
Record views
939
Files downloads
815
