A Global Geometric Framework for Nonlinear Dimensionality Reduction, Science, vol.290, issue.5500, pp.2319-2323, 2000. ,
DOI : 10.1126/science.290.5500.2319
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, pp.2323-2326, 2000. ,
DOI : 10.1126/science.290.5500.2323
Laplacian Eigenmaps for Dimensionality Reduction and Data Representation, Neural Computation, vol.15, issue.6, pp.1373-1396, 2003. ,
Graph Embedding and Extensions: A General Framework for Dimensionality Reduction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.1, pp.40-51, 2007. ,
DOI : 10.1109/TPAMI.2007.250598
Local similarity and diversity preserving discriminant projection for face and handwriting digits recognition, Neurocomputing, vol.86, pp.150-157, 2012. ,
DOI : 10.1016/j.neucom.2012.01.031
A multi-manifold discriminant analysis method for image feature extraction, Pattern Recognition, vol.44, issue.8, pp.1649-1657, 2011. ,
DOI : 10.1016/j.patcog.2011.01.019
Marginal semi-supervised sub-manifold projections with informative constraints for dimensionality reduction and recognition, Neural Networks, vol.36, pp.97-111, 2012. ,
DOI : 10.1016/j.neunet.2012.09.010
Stable orthogonal local discriminant embedding for linear dimensionality reduction, IEEE Transactions on Image Processing, vol.22, issue.7, pp.2521-2531, 2013. ,
A supervised non-linear dimensionality reduction approach for manifold learning, Pattern Recognition, vol.45, issue.6, pp.2432-2444, 2012. ,
DOI : 10.1016/j.patcog.2011.12.006
Out-of-sample extensions for LLE, ISOMAP, MDS, Eigenmaps, and Spectral Clustering, Adv. Neural Inf. Process. Syst, pp.177-184, 2004. ,
Sparse Projections of Medical Images onto Manifolds, Information Processing in Medical Imaging -23rd International Conference, IPMI 2013, pp.292-303, 2013. ,
DOI : 10.1007/978-3-642-38868-2_25
An explicit nonlinear mapping for manifold learning, pp.51-63, 2013. ,
A sparse-grid-based outof-sample extension for dimensionality reduction and clustering with laplacian eigenmaps, AI 2011: Advances in Artificial Intelligence -24th Australasian Joint Conference, pp.112-121, 2011. ,
A generalised solution to the out-of-sample extension problem in manifold learning, Proceedings of the Twenty-Fifth AAAI Conference on Artificial Intelligence, p.3603, 2011. ,
The out-of-sample problem for classical multidimensional scaling, Computational Statistics & Data Analysis, vol.52, issue.10, pp.4635-4642, 2008. ,
DOI : 10.1016/j.csda.2008.02.031
Out-of-Sample Extrapolation of Learned Manifolds, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.9, pp.1547-1556, 2008. ,
DOI : 10.1109/TPAMI.2007.70813
Unsupervised Learning of Image Manifolds by Semidefinite Programming, International Journal of Computer Vision, vol.26, issue.1, pp.77-90, 2006. ,
DOI : 10.1007/s11263-005-4939-z
Locality Preserving Projections, Advances in Neural Information Processing Systems 16, 2004. ,
Face recognition using Laplacianfaces, IEEE Trans. Pattern Anal. Mach. Intell, vol.27, issue.3, pp.328-340, 2005. ,
Orthogonal Laplacianfaces for Face Recognition, IEEE Transactions on Image Processing, vol.15, issue.11, pp.3608-3614, 2006. ,
DOI : 10.1109/TIP.2006.881945
Manifold discriminant analysis, CVPR, pp.429-436, 2009. ,
Marginal Fisher Analysis and Its Variants for Human Gait Recognition and Content- Based Image Retrieval, IEEE Transactions on Image Processing, vol.16, issue.11, pp.2811-2821, 2007. ,
DOI : 10.1109/TIP.2007.906769
Radial Basis Functions, 2003. ,
DOI : 10.1017/cbo9780511543241
The polynomial solvability of convex quadratic programming, USSR Computational Mathematics and Mathematical Physics, vol.20, issue.5, pp.223-228, 1980. ,
DOI : 10.1016/0041-5553(80)90098-1
Ridge regression learning algorithm in dual variables, Proceedings of the Fifteenth International Conference on Machine Learning, pp.515-521, 1998. ,
Semi-supervised learning using gaussian fields and harmonic functions From few to many: Illumination cone models for face recognition under variable lighting and pose, Machine Learning, Proceedings of the Twentieth International Conference, pp.912-919, 2001. ,
Analyzing appearance and contour based methods for object categorization, 2003 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2003. Proceedings., pp.16-22, 2003. ,
DOI : 10.1109/CVPR.2003.1211497
Columbia Object Image Library (COIL-20), Tech. Rep, 1996. ,
