New interface
Journal articles
Inter-Layer Prediction of Color in High Dynamic Range Image Scalable Compression
Mikaël Le Pendu 1 Christine Guillemot 1 Dominique Thoreau 2
1 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : This paper presents a color inter layer prediction (ILP) method for scalable coding of High Dynamic Range (HDR) video content with a Low Dynamic Range (LDR) base layer. Relying on the assumption of hue preservation between the colors of an HDR image and its LDR tone mapped version, we derived equations for predicting the chromatic components of the HDR layer given the decoded LDR layer. Two color representations are studied. In a first encoding scheme, the HDR image is represented in the classical Y'CbCr format. In addition, a second scheme is proposed using a colorspace based on the CIE u'v' uniform chromaticity scale diagram. In each case, different prediction equations are derived based on a color model ensuring the hue preservation. Our experiments highlight several advantages of using a CIE u'v' based colorspace for the compression of HDR content, especially in a scalable context. In addition, our inter-layer prediction scheme using this color representation improves on the state of the art ILP method which directly predicts the HDR layer u'v' components by computing the LDR layers u'v' values of each pixel.
Document type :
Journal articles
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-01388961
Contributor : Mikael Le Pendu Connect in order to contact the contributor
Submitted on : Thursday, October 27, 2016 - 5:56:00 PM
Last modification on : Friday, July 8, 2022 - 10:08:02 AM
File
TIP_Color_HDR_Scalable.pdf
Identifiers
Citation
Mikaël Le Pendu, Christine Guillemot, Dominique Thoreau. Inter-Layer Prediction of Color in High Dynamic Range Image Scalable Compression. IEEE Transactions on Image Processing, 2016, 25, pp.3585 - 3596. ⟨10.1109/TIP.2016.2571559⟩. ⟨hal-01388961⟩
Share
Metrics
Record views
207
Files downloads
198
