Deploying Wide Color Gamut and High Dynamic Range in HD and UHD, SMPTE Motion Imaging Journal, vol.124, issue.3, pp.37-49, 2015. ,
DOI : 10.5594/j18530
LogLuv Encoding for Full-Gamut, High-Dynamic Range Images, Journal of Graphics Tools, vol.13, issue.6, pp.15-31, 1998. ,
DOI : 10.1080/10867651.1998.10487485
Backward compatible high dynamic range MPEG video compression, ACM Trans. Graph, vol.25, issue.3, 2006. ,
Lossy compression of high dynamic range images and video, Human Vision and Electronic Imaging XI, 2006. ,
DOI : 10.1117/12.639140
An adaptive Logluv transform for High Dynamic Range video compression, 2010 IEEE International Conference on Image Processing, pp.2061-2064, 2010. ,
DOI : 10.1109/ICIP.2010.5654069
Inter-layer prediction for backwards compatible high dynamic range video coding with SVC, 2012 Picture Coding Symposium, pp.285-288, 2012. ,
DOI : 10.1109/PCS.2012.6213348
Optimizing a tone curve for backward-compatible high dynamic range image and video compression, IEEE Trans. Image Process, vol.20, issue.6, pp.1558-1571, 2011. ,
Visually Favorable Tone-Mapping With High Compression Performance in Bit-Depth Scalable Video Coding, IEEE Transactions on Multimedia, vol.15, issue.7, pp.1503-1518, 2013. ,
DOI : 10.1109/TMM.2013.2266633
Local inverse tone curve learning for high dynamic range image scalable compression, IEEE Transactions on Image Processing, vol.24, issue.12, pp.5753-5763, 2015. ,
DOI : 10.1109/TIP.2015.2483899
URL : https://hal.archives-ouvertes.fr/hal-01204722
Bit-depth scalable coding for high dynamic range video, Visual Communications and Image Processing 2008, 2008. ,
DOI : 10.1117/12.766601
Quantization Techniques for Visualization of High Dynamic Range Pictures, 5th Eurographics Workshop on Rendering, pp.7-20, 1994. ,
DOI : 10.1007/978-3-642-87825-1_2
LCIS, Proceedings of the 26th annual conference on Computer graphics and interactive techniques , SIGGRAPH '99, pp.83-90, 1999. ,
DOI : 10.1145/311535.311544
A perceptual framework for contrast processing of high dynamic range images ,
Gradient domain high dynamic range compression, ACM Trans. Graph, vol.21, issue.3, pp.249-256, 2002. ,
Fast bilateral filtering for the display of highdynamic-range images, ACM Trans. Graph, vol.21, issue.3, pp.257-266, 2002. ,
Perceptual signal coding for more efficient usage of bit codes, SMPTE Motion Imaging Journal, 2012. ,
High dynamic range electro-optical transfer function of mastering reference displays, 2014. ,
Evaluation of Color Encodings for High Dynamic Range Pixels, Proc. SPIE 9394, Human Vision and Electronic Imaging XX, 2015. ,
709, basic parameter values for the HDTV standard for the studio and for international programme exchange, 1990. ,
Color correction for tone reproduction, CIC21: Twentyfirst Color and Imaging Conference, pp.215-220, 2013. ,
Photographic tone reproduction for digital images, ACM Trans. Graph, vol.21, issue.3, pp.267-276, 2002. ,
Call for evidence (CfE) for HDR and WCG video coding, 2015. ,
Creating cinematic wide gamut hdr-video for the evaluation of tone mapping operators and hdr-displays, pp.90-230, 2014. ,
pfstmo tone mapping library ,
The CIEDE2000 color-difference formula: Implementation notes, supplementary test data, and mathematical observations, Color Research & Application, vol.6, issue.1, 2005. ,
DOI : 10.1002/col.20070
HDR-VDP-2.2: a calibrated method for objective quality prediction of high-dynamic range and standard images, Journal of Electronic Imaging, vol.24, issue.1, p.10501, 2015. ,
DOI : 10.1117/1.JEI.24.1.010501
URL : https://hal.archives-ouvertes.fr/hal-00951337
Objective Quality Assessment of Tone-Mapped Images, IEEE Transactions on Image Processing, vol.22, issue.2, pp.657-667, 2013. ,
DOI : 10.1109/TIP.2012.2221725
High dynamic range image compression by optimizing tone mapped image quality index, IEEE Trans. Image Process, vol.24, issue.10, pp.3086-3097, 2015. ,
Calculation of average PSNR differences between RD curves, 2001. ,
